Good evening,
Our construction company plans to build the exterior walls using an unfilled Poroton T12, 36.5 cm (14 inches) thick. The exterior plaster will consist of a lime-cement plaster between 1.5 and 2 cm (0.6 and 0.8 inches) thick, with a 2 mm (0.08 inch) synthetic resin plaster applied on top. The interior wall plaster will be a machine-applied gypsum plaster.
Is this sufficient for today’s standards? Or would it be better to choose a different Poroton brick?
Best regards, Micha
Best regards, Micha
Bookstar schrieb:
That is not correct. Why?
hausbauer26 Dec 2019 00:09In the Leipfinger Bader price list, the Coriso is also significantly cheaper than the unfilled Unipor solid brick. I'm surprised, I always thought it was the other way around.
