ᐅ Exterior window sills – aluminum or made from a facing brick layer
Created on: 4 Jul 2017 12:14
Malz1902
we were just asked what type of window sills we want.
Options: white aluminum or with a facing layer made of brick slips
About the house: 14 windows, white uPVC windows
What would you suggest? Pros and cons?
Knallkörper
7 Jul 2017 11:30
Oh, thanks. Do you use any special masonry anchors?
Malz1902
7 Jul 2017 11:39
I will take a photo for you this evening. I’m not sure if they are special, but they are anchors in the masonry.
Knallkörper
7 Jul 2017 11:42
As far as I know, special approved anchors must be used when there is more than 15cm (6 inches) of spacing between the wythes. That is why we have only 14cm (5.5 inches) plus a 1cm (0.4 inch) finger gap.
11ant7 Jul 2017 12:31
I know anchors are generally common with cavity walls, but this might vary depending on the support, and how strictly they are required.
If you meant the fixation of the glass wool insulation: there will probably be disc anchors (insulation fixings), since it’s difficult to glue it.
Malz1902
7 Jul 2017 21:31
Just remeasured carefully: 16cm (6 inches) of glass wool, 2cm (0.8 inches) of air gap, then the facing bricks.
Knallkörper
7 Jul 2017 22:34
According to the DIN standard, anchors are always required unless other connection devices are in place, correct. This applies regardless of the distance between the layers. However, for distances over 15cm (6 inches), special anchors with an official building approval for the specific application are mandatory. Wire anchors are not allowed. I’m not exactly sure, as I have only seen the version used with 14cm (5.5 inches) insulation and 1cm (0.4 inches) air gap so far.
