ᐅ Exterior window sills – aluminum or made from a facing brick layer
Created on: 4 Jul 2017 12:14
Malz1902
we were just asked what type of window sills we want.
Options: white aluminum or with a facing layer made of brick slips
About the house: 14 windows, white uPVC windows
What would you suggest? Pros and cons?
What is the purpose of the expansion joints (are you building a solid prefabricated house?), and what appearance will the cladding on the side views of the cross gable have?
netuser schrieb:
No, it will be a timber frame with brick cladding. In that case, aren’t expansion joints needed? Oh, timber frame panels. Yes, expansion joints do make sense there.
netuser schrieb:
The "cladding of the side walls" still needs to be "selected." Probably metal sheets? Which would suggest brushed aluminum window sills...? The drawing looks corrugated. I would probably go with zinc sheets here. And the window sills in aluminum, but coated (matched to the color of the windows, but don’t use the "exact same"—keep in mind RAL is not Pantone).
Thank you!
In terms of color combination, brushed aluminum benches will probably provide the best and most uniform appearance. Especially when combined with the zinc sheets on the side walls and the light gray wooden windows. Both in terms of cost and durability/resistance, brushed aluminum will likely be the better choice. Why do you recommend "coated"?
Perhaps anodized aluminum could also look suitable. I find the "natural" brushed finish too light, and the coated one doesn’t appear as rough.
