ᐅ Insulation for Older Buildings Using Ventilated Facade Systems: Design and Structural Analysis
Created on: 1 Apr 2026 10:17
Jan Hieber
Jan Hieber
1 Apr 2026 10:17
Hello!
I live in a detached house built in 1976 with 30 cm (12 inches) hollow brick walls. It has now been divided and is occupied by two families.
The roof and windows have already been renovated, but heating costs remain high.
2 floors, 2 households, plus a basement
Approx. 250 m² (2700 sq ft) of living space. Approx. 4000 € gas per year.
Now I want to insulate the facade myself (with helpers).
I have an energy consultant who advises me on where and how it will be worthwhile.
However, I have questions about the implementation, specifically regarding structural stability.
The setup:
**Z-rails (Z-profiles):**
 * Based on https://passipedia.de/_media/baulich/baulich/diy-anleitung_z-traeger.pdf
 * I will build them myself, from 70 x 45 mm (2.8 x 1.8 inches) Douglas fir construction timber + 5 mm (0.2 inches) hard fiberboard or OSB
**Filling:** cellulose blown in
  The cellulose is held against the Z-rails by 35 mm (1.4 inches) STEICO universal dry wood fiberboards.
**Cladding:** with 24 mm (1 inch) larch boards.
The Z-rails will probably be 16 cm (6.3 inches) thick. Together with the wood fiberboards, I achieve a final U-value of 0.19.
I know it might be advisable to go further, but I don’t want the wall to become too thick because of the views from the windows and other structural constraints.
**My question about structural stability:**
How should I attach the Z-rails to the wall? I would prefer to drill through the timber directly into the masonry – no brackets.
 * With masonry screws? If so, what length, and what should I consider?
 * With anchors? If so, which type would be suitable?
This will need to carry a considerable weight: cellulose approx. 7 kg/m² (1.4 lb/sq ft) at 16 cm (6.3 inches) thickness, plus wood fiberboards and larch cladding.
I plan to fasten the rest with Spax screws, that is the wood fiberboards and battens:
 * Fix wood fiberboards to the Z-rails with Spax screws
 * Counter battens (vertical) screwed through the wood fiberboard into the Z-rails
 * Cross battens (horizontal) screwed through the wood fiberboard into the Z-rails
What do you think? Please be gentle with me – I am handy but not a building physicist…
Should I have the structural stability and fastening checked or calculated by a structural engineer or carpenter?
Greetings from Lake Constance
Jan
Nauer
1 Apr 2026 10:30
Hi Jan,
I can see you’re on the right track and have already thought through a lot. Using 30 cm (12 inches) hollow bricks isn’t exactly ideal when it comes to heat retention and insulation properties, so exterior insulation can definitely unlock a lot of potential. Of course, the €4000 annual gas costs speak volumes. However, with insulation, you always need to find the right balance between thermal performance and the building’s appearance.
Regarding the structural aspect, especially attaching the Z-profiles to the wall: with a profile thickness of 16 cm (6 inches) and the intended load from the cellulose and wood fiber boards, you should use a sturdier approach. Masonry screws are a good choice, but you must ensure they are anchored deeply enough into the masonry. I wouldn’t recommend standard anchors for this. Instead, for this type of wall (hollow bricks), you should use heavy-duty anchors designed to perform well even in less load-bearing masonry, such as Fischer Duopower or Sormat RBS anchors. These anchors distribute load very effectively and provide high holding strength, even with hollow brick walls.
If you don’t want to use anchors, masonry screws can be an alternative as long as you use the correct screw depth and length. Make sure the screws penetrate the masonry at least 80–100 mm (3–4 inches) to achieve sufficient withdrawal resistance. I would also recommend consulting a structural engineer or the company supplying your Z-profiles to verify the exact load capacity, ensuring your construction is safe.
The wood fiber boards and cellulose filling act somewhat like a “beam,” distributing the load, but if you don’t want to make the wall too thick, you should prioritize quality for the Z-profile attachment. After all, the entire setup needs to remain stable over many years and withstand high moisture and temperature variations.
One more important point: the connection between the Z-profile and the wall is crucial. If the load capacity there is insufficient, settlement could occur over time, which you definitely want to avoid. Therefore, I would prefer using heavy-duty anchors rather than relying solely on screws.
Your approach using Spax screws for fixing the wood fiber boards and battens is fine as long as the insulation elements are securely fastened. But for the wall attachment, as mentioned, it’s better to be on the safe side.
