I have a problem with my Malm dressers from IKEA: the drawers squeak quite loudly and annoyingly when opening and closing. I suspect this is due to the plastic or metal runners wearing down from friction or not being sufficiently lubricated. Before trying anything, I would like to know which lubricant is really suitable to reduce the noise and protect the mechanism.
I am particularly interested in the following points:
- What type of lubricant (oil, spray, grease, silicone, etc.) is appropriate for the plastic and metal parts without causing damage?
- Are there products that are safe to use on plastic, since some substances can, for example, damage plastic?
- How often should lubrication be applied to permanently eliminate the squeaking?
- Are there any maintenance tips to extend the lifespan of the running components of the Malm drawers?
I would be very grateful for any advice, as the squeaking is quite bothersome and I would like to solve it effectively and sustainably.
Hello Klachen,
first of all, here is a detailed overview of how I assess the problem and which steps I would recommend to solve it. The typical squeaking of furniture drawers, especially models like the Malm chests, usually results from friction between the runners, the rollers, and possibly the plastic guides.
1. Type of lubricant:
- Dry lubricants based on silicone are usually the best choice, as they are non-sticky, do not accumulate, and do not damage plastic parts. Silicone spray, for example, prevents dust from sticking and provides long-lasting lubrication for the mechanism.
- If you prefer to use conventional oil, you should choose a light, sprayable machine oil suitable for fine mechanisms. WD-40 is popular but is mainly a cleaner and rust remover, not an optimal long-term lubricant.
2. Application:
- Be sure to clean the runners and rollers thoroughly before applying. Even small dust or paint residues can reduce the effect.
- Use the spray sparingly, ideally a thin layer, and wipe off any excess immediately.
3. Maintenance interval:
- Depending on usage, lubricating once a year should be sufficient for normal household use. If you notice the squeaking returns, you can reapply.
4. Extending lifespan:
- Avoid overloading the drawers, since excessive weight increases friction.
- Occasionally clean the guides to remove dust and dirt.
One more question for you: How old is your Malm furniture? Older models may show wear on the plastic parts, which means lubrication alone might no longer be sufficient.
I hope this helps. If you like, I can also suggest some product examples.
2. Application:
bapar schrieb:
Dry lubricants based on silicone are usually the best choiceI completely agree. Silicone spray is commonly recommended for squeaky furniture parts like drawer slides because it is compatible with both plastic and metal. It is also important that the spray dries clear, leaving no visible residue.
bapar schrieb:
WD-40 is popular but primarily a cleaner and rust remover, not an optimal long-term lubricantThis is a critical point: WD-40 often does not extend service life and can even make squeaking worse after a few weeks or months when the oil evaporates and only residues remain.
As an alternative, PTFE-based sprays, often marketed as “Teflon spray,” can be used and typically offer better long-term effects. However, they are usually more expensive.
Instead of oil-based lubricants, I strongly recommend cleaning the parts first with rubbing alcohol or specialized plastic cleaners to remove contaminants.
Additionally, it makes sense to check whether the drawers are correctly installed and if the guides are bent or worn out. In cases of severe wear, replacing the guides or individual rollers is the only effective solution.
In summary:
- Silicone spray or PTFE spray
- Be cautious with oils or WD-40
- Clean before applying
- Check the mechanics before use
I personally use these products for my furniture and have had good experiences with them.
Interesting and solid points so far! But honestly: Do you really need to dig out a special lubricant for IKEA furniture like the Malm dresser? In my opinion, these established and affordable products simply have their limits, and the best "trick" is often: Just don’t expect too much from these drawer slides.
Honestly, I doubt that expensive special oil or Teflon spray can permanently eliminate squeaking in every case. Especially with plastic slides, noises often result from wear and material deformation.
My tip: If you want to get rid of the squeaking for good and not keep spraying over and over, I would consider replacement parts or possibly exchanging the guide rails. WMF fans probably call it "disposable furniture" – but with heavy use, there are limits.
In short: "Maintenance and tuning" are fine, but the basics have to be right. If that’s not the case, even the best lubricant won’t bring lasting success. 😉
bapar schrieb:I completely agree with that. To be honest: I’ve never had to lubricate a piece of furniture repeatedly; rather, I changed my habits. Less load, keep it clean, that’s it.
Avoid overloading the drawers, as excessive weight increases friction.
