ᐅ Malm drawers come off the runners – how can I prevent this?
Created on: 30 Jun 2021 09:23
rurere
rurere
30 Jun 2021 09:23
I have been having an issue for some time with my Ikea Malm desk where the drawers keep falling out when I open them or even just pull on them lightly. This especially happens when the drawer is quite full—whether with folders or other work materials. I usually use the drawers just for storage and make sure not to overload them. However, I am concerned that the drawers might eventually get damaged from frequently falling out.
That said, I’m not sure if the problem is on my end or if there might be a weakness in the drawer system itself. Has anyone had experience preventing Malm drawers from coming off the rails? Would a technical solution or an additional part be useful? Or perhaps an adjustment in how the drawers are inserted?
I would really appreciate it if you could share your tips, solutions, or experiences—also if you use completely different furniture and have solved a similar problem.
LOGEMIN
30 Jun 2021 10:07
Hi! The issue with Malm drawers falling out is actually more common than people think. In many cases, it’s due to the design of the drawer slides. The Malm series uses simple roller guides where the drawers are held without additional locking mechanisms.
What I recommend is first to check if the drawers are properly mounted. To insert the drawer correctly, you should push it in until you feel a distinct click. Especially if the slides are dirty or damaged, this clicking can be harder to achieve.
As a technical solution, there are so-called “drawer locks” or “retaining clips” that prevent the drawers from being pulled out completely. These are often available as accessories for Ikea furniture.
Another option is to attach self-adhesive stoppers or even felt strips to the sides, which help to hold the drawer in the slide – this significantly slows down the drawer from falling out. It’s important to keep the slides clean and free from obstructions.
In summary: 1. Check cleanliness, 2. Verify proper mounting, 3. Install additional safety devices. I hope this helps you for now!
minan
30 Jun 2021 14:42
I want to go one step further so you can fully understand what might be causing this and how to prevent or at least minimize it.
If you say the drawers tend to come off especially when fully loaded, weight obviously plays a major role. The Malm drawers are designed for a specific maximum weight (usually around 15-20 kg per drawer, depending on the model). Exceeding this significantly increases the force on the rollers and the entire guide system.
From a technical perspective, the Malm drawer slides work more like roller bearings than traditional telescopic slides with locking points. If the rollers wear out partially, start sticking, or the drawer does not move properly on the rollers, the holding security can no longer be guaranteed.
Here are a few points you should check:
1. Are the rollers undamaged and not too dirty? Remove the rollers, clean them thoroughly (e.g., with some isopropyl alcohol or a mild cleaning agent), and inspect for damage.
2. Is the load within the specified limits? If you store very heavy items, consider distributing the weight across multiple drawers or using alternative storage.
3. Have you checked if the drawer properly locks into place when pushed in? Sometimes a misalignment of just a few millimeters can prevent it from locking in.
4. By the way, replacement parts are available from Ikea if a roller or drawer slide is damaged—don’t hesitate to replace them.
Finally, one basic rule: especially with furniture that uses roller guides, make sure to load the drawers evenly. Place heavy items toward the back and distribute the load well to avoid levering the drawer out.
If you like, you could describe more precisely how you load the drawers and whether you’ve already checked if the slides or rollers are damaged?
raulso
1 Jul 2021 08:19
Hey, that sounds really frustrating if the drawers keep sliding out on you 😉
I had a similar issue with a Malm nightstand and found a simple solution: I didn’t overfill the drawers and always pushed them in straight until I heard a small click. That way, they sat firmly in the sliding mechanism.
Another helpful tip is to attach a small piece of foam or sponge at the back of the drawer where it meets the furniture frame. This creates a slight stop and reduces the momentum when you open the drawer. Not high-tech, but simple and effective.
LOGEMIN schrieb:
Make sure the drawer slides are clean.
I think that’s really important—dirty slides increase friction and can cause the drawer to unexpectedly jump out when pulled.
Fingers crossed these little tricks help improve the situation! 🙂
Tause
1 Jul 2021 16:03
I am reading with interest and would like to point out that this topic deserves a somewhat more critical examination.
First of all, I wonder if the issue is structural in the design of the Malm series. It seems that rather inexpensive materials and simple mechanisms are used here, which represent a certain weak point.
minan schrieb:
The Malm drawers are designed for a specific maximum load (usually around 15-20 kg per drawer) (33-44 lbs per drawer).
Here the first misunderstanding arises for many users – the maximum load specifications are often not seen as an absolute limit, but rather as a guideline under which everything works well.
It is quite possible that repeated overloading and lack of maintenance cause the slides and rollers to wear out faster, making the drawers inevitably prone to coming off the tracks.
LOGEMIN’s suggestion of adding extra safety measures sounds like a repair rather than a real solution to the problem. In the long term, replacing the drawer runners with higher-quality systems would probably be more advisable, especially if the furniture is heavily used on a daily basis.
Finally, my question to the original poster: How often does the drawer come off in everyday use? Does it happen with empty or lightly loaded drawers as well, or only when heavily loaded? This would help to determine the cause more precisely.
Devin
2 Jul 2021 07:56
Brief and to the point:
1. Always push drawers in completely until they click into place.
2. Distribute the load evenly when placing heavy items.
3. Check for dirty or damaged runners and clean or replace them as needed.
4. Install additional safety locks if available.
This ensures the drawer stays securely in place.
