ᐅ Linoleum kitchen flooring, available as click-lock planks or rolled sheets
Created on: 8 May 2015 13:34
Sonnenanbeter
Hello Forum,
We want to install linoleum flooring with underfloor heating in our kitchen in our new build. However, it is only about 15sqm (160 sqft).
My husband only knew linoleum as sheet material, as it was installed that way in his parents’ house. During our research at specialty stores, we were only offered so-called click-together tiles, similar to laminate flooring. One dealer told me that it should be installed as a floating floor, while another said the tiles need to be glued down.
The fact is, the floor should stay in place for quite a long time—let’s say at least 20 to 30 years.
What is also unclear to us is what happens with the seams in these click-together tiles, since the floor is not heat-welded together like sheet linoleum. That means water could potentially penetrate the seams during mopping, drips, etc., and we definitely want to avoid those unsightly "swelling" issues like with cheap laminate floors in rental apartments.
Does anyone have experience with this and can offer advice?
We plan to do the installation ourselves, similar to how we have laid wooden floors, as my husband has carpentry experience with floor installation.
Thank you all!
EveundGerd15 May 2015 23:14
First of all, with turnkey house construction, there is a selection process for materials and finishes, often even a preliminary selection. Admittedly, it takes time, but it is especially worthwhile to take a closer look at the products used in interior finishing. The internet provides a lot of information. Manufacturers offer detailed product information...
Problem: not every certification label found on the market is reliable (see various organic labels in the food sector). A product can still be contaminated despite having a label. In the past, this was often the case, especially in the organic sector.
Bieber0815 schrieb:
Regarding external thermal insulation composite systems (ETICS), I would distinguish between ecological requirements and the desire for a healthy lifestyle. The former is difficult in our civilization; the latter can be achieved. In my opinion, it primarily depends on what you bring into your home.
Yes, you are right there.
However, if you follow that logic consistently, you would also have to question the materials of furniture (e.g., sofa or mattress), avoid fleece wallpapers, and also reconsider curtains and many other things.
In the end, personal preferences combined with the available budget determine the decisions.
Sonnenanbeter
15 May 2015 23:16
Interesting discussion!
May I ask what you think about OSB boards in this context? They are used in the wall construction of our timber frame building.
EveundGerd15 May 2015 23:32
Harmless and environmentally friendly.
However, I cannot assess how effective they are for sound insulation.
Bieber0815
16 May 2015 11:01
The adhesive used in OSB boards also comes from the chemical industry (which I don’t consider a negative thing, I’m just mentioning it). Formaldehyde emissions are apparently no longer much of an issue, especially when the board is installed out of sight. So, from a health perspective, they are clearly safe and environmentally acceptable.
In my opinion, OSB boards are still too light and thin for effective soundproofing. However, in timber frame construction, the insulation placed between the studs takes care of that, right?
Sonnenanbeter
16 May 2015 11:11
Of course, soft fiberboards will be installed there.
