ᐅ Lift-and-slide door vs. tilt-and-slide door
Created on: 27 Jan 2016 10:45
sirhc
sirhc27 Jan 2016 10:45
we are currently considering which type of patio door to choose.
We are undecided and have done some online research.
I would appreciate it if you could add any points or correct any mistakes.
Lift-and-slide door:
- used to be less airtight, now equally airtight
- better sound and thermal insulation
- little to no threshold
- only open/close function
- more expensive
- more stable/durable
Tilt-and-slide door:
- equally airtight
- better protection against forced entry due to mushroom-head locks
- threshold present
- tilt function available
- less expensive
- less stable/durable
Most likely, these points do not tell the whole story, so I would be interested to hear which option you chose and why.
Thanks and best regards
Legurit
27 Jan 2016 11:32
This has been discussed several times.
What exactly do you mean by expensive?
lastdrop27 Jan 2016 11:40
My PSK door is "louder" than a lift-and-slide door because I always have to press it firmly into the frame.
If I had to choose today, I would go for a lift-and-slide door...
sirhc27 Jan 2016 12:41
BeHaElJa schrieb:
This has been discussed several times already.
Am I in the wrong place here? Do you have a link? The outcome of the discussion would be interesting. I can’t tell you exactly what more expensive means; I’ve only listed the results of my research. Part of the question is also whether that is even correct.
Legurit
27 Jan 2016 16:55
We paid an additional cost of nearly €1000 for upgrading from a standard 3-meter (10 feet) window door element to a lift-and-slide door. I would therefore be interested to know the extra cost for the parallel sliding and tilt door (PSK).
Bieber0815
27 Jan 2016 21:02
I consider the tilt function unnecessary, so I prefer the lift-and-slide door at the front. If costs are a factor, wouldn't a standard tilt-and-turn door be an option?
