ᐅ Kitchen – Handleless or Rail-Mounted Handles?
Created on: 15 Jan 2023 19:04
wirsanieren202
We are currently planning our kitchen. Personally, I prefer a white, handleless kitchen. My husband thinks that all fingerprints show on it and therefore wants to have stainless steel trim strips to open the doors.
Do you have any experience? What is easier to maintain? And do you prefer gloss or matte?
Yaso2.023 Jan 2023 20:21
wirsanieren202 schrieb:
Thank you for sharing your experience! I was also wondering about the dish towels and then noticed that there are hanging rails for handleless kitchens. That’s probably what you meant, which wouldn’t work with surface-mounted handle strips, right?
That’s exactly what I meant. You can’t hang them on surface-mounted strips.
There are also those square-shaped things you can attach to the cabinet front to clamp the dish towel, but I didn’t like those either.
As it is now, it works fine for everyday use, but it definitely could have been done better!
23 Jan 2023 20:39
Most stoves have handles. If necessary, you can also stick a hook somewhere for $3.99. Ideally, there is a section of wall in the kitchen…
Tolentino23 Jan 2023 20:40
Yaso2.0 schrieb:
those square things that you can attach to the front, where you can basically clamp the dish towel,
If you at least have a door (corner cabinet?) or a tall pull-out, for example in a narrow cabinet, you can stick those inside and hang the towels there
wirsanieren202
23 Jan 2023 21:07
Tolentino schrieb:
If you at least have a door (corner cabinet?) or a tall pull-out, for example in a narrow cabinet, you can stick those things inside and hang the cloths there.
Inside? Isn't that bad because of moisture?
WilderSueden
23 Jan 2023 21:16
There are also 20cm (8 inches) wide cabinets designed as "tea towel garages," which are open at the front. Of course, this is a matter of personal preference; we decided against it and prefer to use the space for storage instead.
