ᐅ KfW70 standard with a gas condensing boiler and solar panels is definitely not feasible.
Created on: 6 Aug 2014 15:56
TeuPhil
Hello everyone!
Yes, this is the statement from my architect that has been on my mind for quite some time now, and given that houses exactly like these exist—with the certificate I want—I am not quite satisfied with it.
But first, a brief overview of the key data for our planned single-family house, hopefully including the values relevant here:
- 2 full stories with a converted and habitable attic (35-degree pitched roof) with a total heated area of 220 sqm (2370 sq ft) without a basement
- heated building volume: 828 cubic meters (29,240 cubic feet)
- usable area according to energy saving regulations: 265 sqm (2852 sq ft)
- primary energy demand QP: 61.02
- transmission heat loss HT: 0.337
- ventilation heat loss HV: 128.35 W/K
The whole thing will be realized with the following technology and insulation:
- gas condensing boiler with solar thermal for domestic hot water (and heating support option)
- controlled ventilation system with heat recovery
- house orientation: SSW/NNE
- exterior masonry: 365 mm (14 inches) aerated concrete, thermal conductivity 0.035, U-value = 0.229
- pitched roof U-value = 0.19 (currently 20 cm (8 inches) insulation between rafters)
- ground floor slab U-value = 0.298
- aluminum front door U-value = 1.3
- triple-glazed windows U-value = 0.84
As a result, the KfW70 standard is met in terms of transmission heat loss. However, the annual primary energy demand is still problematic.
When I asked how the remaining approximately 11 kWh could be saved in a (also economically) reasonable way, I received the rather general answer: “with a heat pump or a pellet boiler.” But I deliberately chose conventional gas and do not want to deviate from that decision. Also, I suspect that these are hardly the only possible solutions but rather the simplest ones.
Before I take the (already planned) step to consult an energy advisor, I would like to ask the experts here in the forum whether my prospects are really that bleak if I stick with gas as my primary energy source.
Oh, one more thing... the house is not being built by a developer or general contractor. So I’m relatively flexible with purchasing. The cost-benefit factor should just be kept reasonable.
As a final note, here’s the answer in advance to the question: “Why KfW70 in particular?”
I am aware that a KfW85 house can have a lower energy demand than a KfW70 house. Much can be calculated advantageously here (keyword: heat pumps). But ultimately, it’s the “good feeling” of having proof at any time with a certificate that I own a particularly energy-efficient house. How paradoxical that sounds... In the end, I simply want to achieve the best possible energy standard for my budget.
TeuPhil
TeuPhil
8 Aug 2014 17:06
Oh, by the way... Regarding the topic of "let’s see what happens." I had already confronted him with a similarly unusual ruling after an appointment with an energy consultant from the consumer advice center (which was my first point of contact on this matter). The response: "That can’t be right!" Well, it’s not always that simple.
Unfortunately, the consultant from the consumer advice center was just as much of an expert in this field as I was, which was surprising, but considering similar experiences with the consumer advice center on other topics, not unexpected. However, the consultation was free, so you can’t expect too much.
klblb
8 Aug 2014 18:17
By the way, you can access the application form on the KfW website and enter the energy performance data of the house in the initial steps. It immediately shows whether the KfW requirements are met. Only after that are personal data and other information requested.
TeuPhil
8 Aug 2014 18:26
@klblb:
That sounds very interesting! I keep searching and searching, but I just can’t find it.
klblb
8 Aug 2014 19:14
@TeuPhil
If you search for "KFW 153 online confirmation," you will find this web application. HOWEVER, it is now protected by a login. A few months ago, I was still able to try it out.
Sorry!
TeuPhil
8 Aug 2014 19:51
Found!
Unfortunately, registration is only possible as a certified energy efficiency expert.
K1300S9 Aug 2014 07:43
Another note regarding the post created by Bauexperte: For KfW 70, a special site management is not required—only the application at the beginning and the certificate at the end. The effort increases with KfW 55, which is probably why the subsidy is higher there.
Good luck
K1300S
