ᐅ Articulated arm awning: replacing the tension wire
Created on: 19 Apr 2019 11:50
KaterGonzo
KaterGonzo
19 Apr 2019 11:50
Our previous tenant left us a folding arm awning in "excellent condition."
Exterior view of a building with a window, door, and a makeshift clothesline under the window
From a first (layman’s) assessment, the basic structure is okay. The awning can be extended and retracted and feels stable even when fully extended.
I am considering simply replacing the awning fabric. With some rust removal and basic cleaning, the awning should then perform as expected.
Problem 1: Tension cable broken in one of the two folding arms
Is it possible to replace this? As far as I can tell, the tension cable is hooked onto a latch and then secured with an adjustment screw? That should be easy to fix, right, or am I mistaken?
Exterior pipes and building service lines on a facade, damaged cover visible
Black and white photo of a staircase handrail with screw connections at a construction site.
Problem 2: Slight misalignment
The awning does not extend straight but is about 20-30cm (8-12 inches) crooked. I assume this is related to the broken tension cable.
Patio roof with a striped awning in front of glass sliding doors of a house.
What do you think? Repairable or total loss?
Here are some details and pictures:
Width: 4.40m (14 feet 5 inches)
Depth: 2.62m (8 feet 7 inches)
