Our shell is already halfway built, and since our budget still allows it, I’m considering installing a solar panel system on the roof. The problem is that it’s a single-pitch roof with a 16° (16-degree) slope facing north.
Additionally, we have a heat pump with underfloor heating in a KfW 70 single-family house.
Is it worth it under these conditions?
nordanney22 Apr 2014 23:10How about a photovoltaic system? Is a high self-consumption rate possible? If needed, it can be cost-effectively financed through the KfW.
Although the feed-in tariff itself is low (hence the question about self-consumption – also considering your heat pump), the prices for photovoltaic systems have dropped significantly.
In any case, we have decided to go with a photovoltaic system.
toxicmolotof23 Apr 2014 08:13It probably won’t be worthwhile at all unless you build a raised substructure.
But maybe there is a garage or an extension. For solar thermal support—not photovoltaic—it might be enough for a single-family house in a good location.
