ᐅ Is a garage door width of 2.25 meters sufficient, or is it rather too narrow?
Created on: 25 May 2018 08:47
Pädda
Hello.
Is a garage door width of 2.25m (7 ft 5 in) sufficient to drive a mid-sized car through?
toxicmolotof25 May 2018 12:53nordanney schrieb:
It depends on the car. A Sharan won’t fit through unless the mirrors are folded in. For a Passat, it would be very tight (if it fits at all).I don’t know which Sharan you drive, but with mine, you are even allowed to drive in construction zones and in areas with a 2.1m (6 ft 11 in) height restriction on the left lane. With the mirror caps, the 2011 model measures 208.1cm (82 inches).Pädda schrieb:
Thank you. Thanks to you, I can now put this into perspective. Some of the answers were really funny... 🙂It is a funny question after all 😉
toxicmolotow schrieb:
I don’t know which version of the Sharan you drive, but with that one you’re even allowed to drive in construction zones with a 2.1m (6 ft 11 in) width restriction in the left lane. Including mirror caps, the 2011 model measures 208.1cm (82 inches).Just because vehicles up to 2.10m (6 ft 11 in) wide are allowed doesn’t mean the lane itself is only 2.10m wide. Minimum clearances still need to be maintained despite a vehicle that is 2.10m wide.
By the way, be careful with the width stated in the vehicle documents—it’s usually without mirrors. ;-)
toxicmolotof25 May 2018 22:35Alex85 schrieb:
Just because vehicles 2.10m (6 ft 11 in) wide are allowed to drive there doesn’t mean the lane is only 2.10m wide. Minimum clearances must still be maintained, even with a 2.10m wide vehicle.
By the way, be careful with the width stated in the vehicle documents; that is without mirrors. ;-)Come on... that’s why I said from mirror end to mirror end. And if the vehicle is 2.11m (6 ft 11.5 in) wide it will probably still fit, but it’s not allowed to drive there.
If a car is 2.08m (6 ft 10 in) wide, it will likely fit through a 2.25m (7 ft 5 in) wide gate, although it will be tight. Even a Ford Mustang fits through there.
Caspar202026 May 2018 06:21The real question is what is behind the gate. Is the interior width of the garage also correspondingly narrower? That is much more important than the drive-through opening when it comes to comfort while getting in and out.
Caspar2020 schrieb:
The question is what is behind the gate. Of course, you have to subtract some width from the nominal clear passage width if you need to change direction immediately behind it. In my opinion, only the clear width for straight entry really matters. A garage door is wide enough when, theoretically, you wouldn’t cause any scratches even when driving in drunk. I have never recommended less than a rough construction nominal width of 251cm (99 inches).
