ᐅ How to Seal Conduits with Underground Cables?
Created on: 2 May 2024 07:00
FrankChief
Good morning,
We want to install a conduit with underground cable in the garden for 1-2 outdoor sockets. We plan to run the underground cable inside the conduit to protect it and allow for replacement.
The conduit would end just before the outdoor socket (pedestal socket) underground and exposed to the elements.
How can we properly seal the end to prevent water, sand, dirt, or animals from entering the conduit?
Should we foam the end of the conduit? If yes, with what?
Or should we use a waterproof heat-shrink sleeve?
Or is there another recommended method?
We only want to install one underground cable 3x2.5mm inside the conduit, so DN25 should be sufficient, right?
Can you recommend a conduit?
Mahri237 May 2024 15:42
I routed my electrical cable to the garden shed inside PE water supply conduit, for example. This way, it is protected from external influences and the electrical cable won’t be accidentally scratched during the first shovel strike. Just a suggestion: costs for about 25 meters (27.00 euros).
MachsSelbst
7 May 2024 17:48
If you want to sleep better, install an empty conduit. But make sure it’s a KG pipe with a diameter of 100mm (4 inches). Trying to push an NYY 3x2.5mm² cable through a 50m (160 ft) M25 conduit will be a real challenge. You’ll probably end up snapping the pull wire made of LiYCY 2x2x0.25, which is usually placed inside.
In general, NYY cables can be laid directly in the ground since they are designed for that. They don’t just break easily—there are tens of thousands of kilometers of NYY cables buried all over Germany for decades without issues.
If you go at it full force with a spade or pickaxe, I’d be more worried about your own safety than the cable’s. That’s why a precise plan, showing exactly where and how deep you’ve laid everything in your garden, is far more important than a protective conduit.
Allthewayup
7 May 2024 19:25
As mentioned before, place a sealing plug at the end and preferably secure it with construction silicone to prevent it from popping out on its own. When installing our 8 empty conduits outdoors, I made sure that the pressure-resistant Kabuflex conduit starts as close to the house as possible to avoid crushing the standard conduit during compaction. I also ensured there was always a slight slope of the conduit away from the house; otherwise, potential condensate would flow back into the house. The ends of the conduits were then buried in the ground with the openings facing downwards (the lowest point of the pipes). Sand was placed on top, followed by gravel, then compacted, and done. Oh, and don’t forget to document the routing of the conduits.
