I have a walk-in shower with an integrated shower channel. I clean it regularly. After about two years, light limescale deposits have become visible. Of course, I can easily descale the removable part, but unfortunately not the channel itself. How should I proceed here?
Seal the drain and then pour in a mild mixture of citric acid? The shower channel should easily withstand that, right?
Bookstar schrieb:
But you can’t see the lime stains at all? Why do they bother you? That’s true. They still bother me, though—I’m not exactly sure why ;-)
How do you descale other items? Use descaling pads, then you’ll get rid of lime scale even in stubborn spots. For everything else, I soak it in citric acid or vinegar or clean it regularly so that stubborn lime scale doesn’t build up in the first place.
Thanks for the tip—descaling pads were new to me.
jaeger schrieb:
I soak everything else in citric acid or vinegar as needed, or clean it regularly so that no stubborn limescale builds up.Fittings? Do you unscrew them? Anyway: Akupads are nothing new or a miracle solution. If you don’t have those, an aluminum scrubber also works—both are common household cleaning tools used for everyday cleaning by homeowners where the surface doesn’t need to be protected.
