ᐅ How do you secure Ikea Pax wardrobes to basement walls?
Created on: 25 Jun 2022 08:37
Bapifu
I am planning to install several Ikea Pax wardrobes in my basement room. I intend to secure the back panels of the wardrobes to the basement wall to ensure greater stability and to prevent tipping.
My question is: what is the best way to safely attach an Ikea Pax wardrobe to a concrete basement wall? Which fasteners are suitable, what steps should I follow, and are there any special considerations to keep in mind (e.g., surface-mounted electrical conduits or moisture)? I am familiar with the basic functions of the Pax units but need specific recommendations for securely fixing them to basement walls, which are often rough and uneven.
Thanks in advance!
V
vin_leo
25 Jun 2022 17:03
Keatondra schrieb:
A cladding that is firmly anchored to the wall can serve as an indirect stabilizing element.
Exactly! And it usually looks better if you not only secure the back wall but also create an attractive facing.
If you also have a spirit level and some wedges ready, the whole setup will be more stable than many high-rise buildings. 🙂
Bapifu
26 Jun 2022 08:15
Thank you all for the detailed and helpful responses! To summarize, stainless steel heavy-duty anchors, preferably made of stainless steel, with at least two secure fixing points per cabinet side are recommended. Additionally, using shims to compensate for uneven walls is useful, and an extra wall panel or cross brace can significantly improve stability at greater heights. I will now get the parts and drill carefully. If any further questions arise, I will reach out again. Many thanks to everyone here!
Gino38
26 Jun 2022 09:02
Good luck with the installation! If you like, feel free to share how it went. This way, others with similar questions can benefit from your experience.
V
vin_leo
26 Jun 2022 09:45
Sure, keep us updated and don’t forget to make the installation a bit enjoyable – even if drilling into concrete isn’t always fun. 😉
