ᐅ How do I securely fasten IKEA Brimnes furniture to the wall?
Created on: 20 Jan 2023 08:34
Sieur38
I plan to securely and permanently attach my IKEA Brimnes wardrobe to the wall. Although the IKEA assembly kit includes dowels and brackets, I want to ensure the mounting is stable and minimizes the risk of tipping.
I have a few questions where I would appreciate your experience and advice:
- Which type of anchors and screws are best depending on the wall type (e.g., concrete, drywall, brick)?
- How many mounting points should be used at a minimum?
- Are there any special tips for properly aligning the wardrobe and making it tip-resistant?
- Should additional precautions be taken, especially if there are children in the household?
I look forward to your knowledgeable answers and any advice on mistakes to avoid. Thank you in advance!
Sieur38
21 Jan 2023 11:47
Roberta schrieb:
If the Brimnes is placed on linoleum or carpet, you should put rubber pads under the legs
Good tip! My floor is laminate, but I will still put some non-slip material underneath. Thanks!
kieran
21 Jan 2023 14:02
One final point: Before drilling, you should check the wall for cables or pipes, preferably with a wire detector. This avoids dangerous damage and saves time.
retau
21 Jan 2023 15:37
Perfect that there is such thorough discussion here! I wish you much success and look forward to positive feedback once the Brimnes is securely in place!
Sieur38
22 Jan 2023 08:24
Thank you all for your support! I have now chosen suitable heavy-duty anchors, installed two fasteners on each side, and am double-checking everything.
I will test this as soon as possible and report back with the results.
