ᐅ How can I reinforce Malm drawer slides?
Created on: 11 Nov 2017 18:07
Elmo41
Elmo41
11 Nov 2017 18:07
I have several Malm dressers with the typical IKEA drawer slides. While they are affordable and practical, the slides seem to give way quickly under heavy load or frequent use – the drawers sometimes run roughly or stick, and everything feels unstable, especially with heavy items.
My question is: What is the most effective way to reinforce Malm drawer slides to significantly improve stability without altering the mechanism or design too much?
What are your tips for a solid reinforcement? Are there special additional profiles, different screw techniques, or even alternative slides that can be installed?
I look forward to your experiences and ideas!
JUHAU
11 Nov 2017 18:45
The easiest way to reinforce is by attaching additional metal angle brackets to the sides of the drawers and the cabinet. This helps to distribute the load more evenly.
Additionally, using a thread locker (avoid lubricants on screws) ensures a more secure hold of the screws in the wood.
klabe
12 Nov 2017 08:23
Hello Elmo41,
to noticeably reinforce your Malm drawer slides, I recommend the following steps:
1. Check the screws: Usually, the mounting screws are loose. First, tighten all screws securely and replace any damaged ones with new screws of the same diameter.
2. Reinforce the attachment points:
- For the cabinet carcass, you can install small metal brackets to add extra stability.
- Adding wooden strips inside the cabinet carcass, to which the slides are screwed, also increases the support surface.
3. Replace the drawer slides:
- Malm usually uses basic ball-bearing slides. An alternative is heavy-duty telescopic rails, which are relatively easy to install.
- These provide much better stability under higher loads.
4. Maintenance and adjustment:
- Make sure all sliding tracks are clean and treated with lubricant.
Common mistake: Not screwing the screws fully into the appropriate threaded insert or anchor, which can cause the wood to split.
I hope these tips help you. If you need ikea-specific measurements, I can look them up for you.
rekijan
12 Nov 2017 09:47
JUHAU schrieb:
The easiest way is to attach additional metal angle brackets to the drawer sides and the cabinet.
True, those angle brackets can really be a lifesaver when things are a bit wobbly.
I added a small metal reinforcement to my Malm drawer, and since then it’s been working like new. A bit of threadlocker on the screws, and everything holds tight.
Plus, it’s hardly visible, so no worries about the appearance! 🙂
Sometimes, a simple wooden strip on the side where the drawer slide is installed is enough—acting like a small brace against bending.
Oh, and another tip: heavy-duty drawer slides are actually quite affordable online if you want to try something new and improve stability.
bareynaldo
13 Nov 2017 12:56
I think the whole IKEA Malm reinforcement thing is a bit overrated. Sure, the original drawer slides aren’t the most robust, but as long as you don’t fill the drawers with sandbags, they’re usually sufficient.
klabe schrieb:
One alternative is heavy-duty telescopic drawer slides, which are relatively easy to install.
In my opinion, that’s the better approach – either replace the slides entirely with higher-quality ones or use some tricks like adding wooden strips and brackets.
But honestly: if you increase the load significantly on a permanent basis, even that won’t last forever. So it’s better to invest in professional-grade hardware that doesn’t get stuck, warp, and can handle a proper load capacity.
Just my two cents. If you prefer a more casual approach, of course you can stick with the small improvements. 😉
