I’m planning to replace the handles on the drawers of my Ikea Malm dresser because I don’t like the old ones and would like a more personalized look. My question is: How can I properly remove the handles and install new ones without damaging the drawers or compromising their stability?
I have read that Malm drawers are often secured with screws from the inside, but I’m unsure about the procedure – especially whether I need any special tools or if there are any particular considerations regarding the screws and the material.
Also, I’m interested in whether I need to pay close attention to the drilling holes when choosing new handles, meaning if all Malm drawers have the same dimensions, or if I should be cautious.
I would appreciate any tips on how to systematically and safely replace the handles – maybe from your own experience. Thanks in advance!
ripra46 schrieb:
How can I properly remove the handles and install new ones without damaging the drawers or compromising their stability?Hi ripra46,
first of all, don’t worry—replacing handles on Malm drawers is actually quite straightforward, almost a DIY classic 🙂 You usually only need a Phillips screwdriver (preferably magnetic so the screws don’t fall) to remove the handles. Malm drawers are screwed from the inside, so just pull the drawer out completely, loosen the screws holding the handles, and take off the old handles.
When installing the new ones, make sure the handle holes match—the Malm series is pretty standardized, usually with a 128 mm (5 inches) hole spacing, but if you have handles from other collections or custom-made ones, it’s best to measure again.
If everything fits: insert the screws and tighten them lightly—overtightening can easily distort the drawer frame. It’s better to tighten firmly and then check if everything sits properly.
Pro tip: To prevent the new holes from fraying if you’re making new ones for handles with a different hole spacing, you can use small washers to add some reinforcement.
So: stay relaxed, grab your tools, and enjoy updating your Malm drawers! 🙂
loken schrieb:
Sometimes a hole center distance of 128 mm (5 inches) is common for handlesExactly, a spacing of 128 mm (5 inches) is indeed the standard for the Malm dressers with drawers, at least for the larger models (e.g., 3- or 4-drawer versions). For smaller drawers or other models, it can vary, so I always recommend measuring the handle hole distances carefully before replacing handles.
Here are some organized steps on how I would suggest handling this:
1. Fully remove the drawer and place it on a clean work surface.
2. Unscrew the handles from the inside—usually cross-head screws.
3. After removing the handle, quickly inspect the drilled holes for damage—if the holes are frayed or worn out, you can easily repair them from the inside with some wood glue and wood filler to maintain stability.
4. Fit the new handle—make sure the screws are not too long (to avoid damaging the back of the drawer).
5. Tighten the screws with light to medium torque, never too tight to prevent deforming the material.
6. Reinsert the drawer and check for a secure fit.
Regarding tools: A simple cross-head screwdriver or a cordless drill with torque control is very helpful. Older or stuck screws can sometimes be difficult due to rust or material deformation—then a few drops of WD-40 or a similar lubricant can help before applying force.
One point to clarify is the type of material your drawers are made of. Are they wood veneer, MDF, or particleboard? For MDF, for example, caution is needed because it can swell or chip easily if screws are inserted and removed too often or tightened too much.
BENBI schrieb:
Tighten screws with light to medium torque, never too tight, to avoid deforming the material.Good point. I’d like to add here that the choice of screws also matters. Original handles usually come with screws that are the exact right length and thickness. When buying alternative handles, this factor is often overlooked.
Screws that are too short cause loose handles, while screws that are too long can damage the back of the drawer, which in the worst case can affect stability.
My personal recommendation: Check the screw and hole measurements before buying handles and, if necessary, order additional suitable screws—some use an M4 threaded screw, but it’s worth taking a close look.
Also: For added security, you can attach the handles with a small piece of double-sided tape on the back of the drawer to improve fixing.
However, I see this as a supplementary measure rather than a substitute for screws.
Has anyone here had experience with other fixing methods for Malm handles?
Victor54 schrieb:
Has anyone here had experience with alternative fastening methods for Malm?From my perspective, the clear answer is: No. IKEA designs Malm handles primarily for screwed attachment; this is engineered to provide a reliable and replaceable solution.
Adhesive or other fastening methods such as nails or clips are generally unsuitable for functional furniture parts, as they do not offer sufficient tensile or compressive strength, especially on frequently used drawers.
An important tip when replacing handles: if the drill holes are damaged from previous handles, you should seal the area with varnish or an appropriate wood repair kit before installing new handles. This prevents moisture damage and ensures long-lasting stability.
A final note: not every replacement handle set includes screws that comply with IKEA standards; therefore, it is advisable to adjust the screws or use the originals if the handle fits.
In terms of tools, a good Phillips screwdriver and a tape measure are sufficient. Using a cordless drill with too much torque can cause damage and is only recommended with careful handling.
draleo schrieb:
From my perspective, the clear answer is: No, IKEA Malm handles are fundamentally designed for screwed attachmentI can confirm that – and here’s a small tip for handling:
If you have several drawers to fit with new handles, it’s recommended to organize the screws systematically (for example, in small containers or on a magnetic strip) to avoid mixing them up.
Also, the order of screwing is crucial: always tighten the screws by hand first before fully tightening them, to ensure even tension and proper alignment.
If the surfaces are affected by the screws or dents occur (for example, if the screwdriver slips), small felt or rubber pads placed between the screwdriver and the handle can help prevent scratches.
Don’t forget to check all handles for a firm fit after installation, as screws can sometimes loosen slightly during initial use.
Good luck with the handle replacement – and if you have any questions about tools or drawer types, feel free to ask!
