ᐅ How do I clean Ikea Metod glass cabinet doors?
Created on: 24 Feb 2022 09:17
phillip46
Hello everyone, I have Ikea Metod kitchen fronts with glass. I find cleaning these glass fronts a bit challenging because I want to avoid streaks or unnecessary scratches. Could you please give me specific tips on how to clean these Ikea Metod glass fronts gently and effectively? It would be helpful to know which cleaning products are suitable, whether special cloths or techniques should be used, and if there is anything that should definitely be avoided. Thanks in advance for your help!
Julien
25 Feb 2022 09:30
Very good question. I would recommend wiping the glass fronts roughly at least once a week to remove dust and fingerprints. Intensive wet cleaning should be done at most once a month or as needed. Frequent scrubbing with cleaning agents or aggressive substances can actually wear off coatings or cause scratches. So it’s better to clean lightly and regularly, and only perform thorough cleaning when there are visible stains, to preserve the surface for a long time.
kemeo68
25 Feb 2022 10:45
phillip46 schrieb:
Apparently, it's a balancing act between thorough cleaning and gentle, material-friendly methods.
That's exactly how I see it. But honestly, if someone is afraid of damaging the surfaces, they probably don't clean them very often, right? You also have to be a bit relaxed about it. As long as no sandpaper is used, glass fronts usually withstand frequent cleaning.
LOGEMIN
25 Feb 2022 11:20
phillip46 schrieb:
Are there any experiences regarding how often glass façades should ideally be cleaned without causing damage?
A simple rule of thumb: "The gentler the cleaning, the more often it’s allowed." However, the cleaning frequency also depends on how the space is used. In a kitchen with a lot of cooking, grease splatters, and finger contact, cleaning once a week is usually sufficient, or even more often if you are very attentive. In less frequently used areas, cleaning every two to three weeks is enough.
I always recommend carefully cleaning as needed using water and a mild detergent, and removing visible grease residues immediately, as these become more difficult to remove over time.
nonpra
25 Feb 2022 14:55
One more tip from me: Sometimes the problem with streaks is not the cleaning method but improper drying. It is best to use a clean, dry microfiber cloth and dry the glass thoroughly immediately after washing to prevent water spots.
phillip46
26 Feb 2022 09:05
Here is a summary: - Use microfiber cloths that are soft and smooth, with no rough sides. - Cleaner: mild dish soap in lukewarm water, very diluted vinegar is also possible. - No alcohol or abrasive cleaners. - Use gentle motions and immediately dry afterward to avoid streaks. - Clean about once a week or depending on usage. Thank you all for the very detailed and helpful tips, they really help me a lot!
