ᐅ How can I clean Ikea Metod countertops effectively and gently?
Created on: 8 Jun 2020 09:17
Bekelechi
Hello everyone, I recently bought an Ikea Metod kitchen with countertops made of a rather sensitive laminate material. Unfortunately, the surface seems quite prone to stains and scratches, so I’m unsure how to clean the countertops effectively and, most importantly, gently without damaging them or causing the surface to become dull. Could someone please share tips on which cleaning products to use, whether it’s necessary to avoid abrasive cleaners completely, and if there are any special techniques for removing water spots, grease marks, or light buildup? I definitely want to avoid damaging the countertop unnecessarily since it was quite expensive. Thanks in advance for any advice and shared experiences!
rubybi
9 Jun 2020 09:11
One small tip in case you ever encounter tougher stains on the Metod panel: Place a damp cloth with a bit of mild dish soap on the spot for about 10–15 minutes, which softens the stain and makes it easier to remove.
Make sure the cloth isn’t too wet and no liquid seeps into the joints. Then, simply wipe the area dry with a clean cloth. This helps prevent scratches and protects the surface.
Renegi
9 Jun 2020 10:04
I also think it is important not to place hot pots directly on the countertop. Heat damage is almost irreversible and cannot be prevented by cleaning.
