ᐅ How can large KALLAX units be made more stable when freestanding?
Created on: 20 Apr 2023 08:23
Kinmin
Hello everyone, I recently bought several KALLAX units from IKEA and wanted to place them freely in the room, not fixed to the wall. However, I noticed that especially larger combinations tend to be a bit wobbly and don’t have the desired stability. My question is: How can large KALLAX units, standing freely, be made more stable without screwing them to the wall? Are there practical tips or accessories that can be used to improve their stability? I’m looking forward to your experiences and ideas!
Kinmin
20 Apr 2023 10:44
That helps a lot already, thank you. Also: Does anyone have experience using weights in the bottom compartment? I have read that adding weight at the bottom can lower the center of gravity. Could that be a useful additional measure?
Gloriagl10
20 Apr 2023 11:02
Placing weights at the bottom can have a stabilizing effect, especially if the modules are tall and narrow. However, make sure to distribute the weight evenly; otherwise, the shelving unit may tip over unintentionally.
TAUFA
20 Apr 2023 11:23
Additionally, you can also run galvanized metal rods through the inner compartments if the shelves are too wobbly. This greatly improves stability.
Kinmin
20 Apr 2023 13:11
Interesting, @TAUFA! Do you mean vertical rods that you insert through the compartments? Or horizontal ones? How exactly are they fixed in place? Does this work without having to drill holes?
I’m trying to make as few visible and permanent changes as possible, as I might want to use the modules differently in the future.
reni45
20 Apr 2023 13:35
These are usually horizontal crossbars that can be hooked in relatively easily. Most of them require at least small drill holes in the sidewalls; otherwise, they are not secure enough.
JAFUHAU
20 Apr 2023 14:00
I can understand the concern about stability; free-standing furniture can certainly give you an uneasy feeling, especially when you have children. Maybe you could use multiple connection points: brackets, joining fittings, and additionally weights at the bottom – this way you have a double layer of safety.
