ᐅ Home Renovation Electrical Planning: Future-Proof?
Created on: 28 Jun 2022 12:55
Westfale0101
Dear electrical experts,
A few months ago, we purchased a house from the 1960s and are currently renovating it. Our goal is to move in around Christmas, but it wouldn't be too problematic if it takes longer since we are doing much of the work ourselves.
At the same time, the electrician has asked us to prepare a plan that he can then implement in coordination with us. And this is where you come in... As a layperson who has gone through several threads, I hope you can help or confirm the plans.
Briefly about the house:
- Single-family house with ground floor (GF) and upper floor (UF), plus an unfinished attic and a cellar for utility purposes (all with concrete walls)
- The screed has been removed everywhere except the stairwell, and underfloor heating including a heat pump will be installed / roof renovation is still to come; issue: low screed thickness of 6–8cm (2.4–3.1 inches). According to the screed installer and the plumber, this will work
- Two technical rooms in the cellar, one (Technical Room 1) for electrical systems / distribution board / fiber optic (already installed) and one (Technical Room 2) for the heat pump technology
- On the GF, the living/dining room with the TV and satellite connection is somewhat suboptimal (drawing to follow) due to light incidence/windows/etc.
- On the GF, above Technical Room 1 is a future storage room, where the router will be placed, including possible switches / distribution to the rooms
- On the UF, there are three children's rooms, a bathroom, and a 6 m² (65 ft²) room created by a new partition, which has yet to be fully planned (an access point is to be installed here to a) extend WLAN coverage upstairs and b) provide Wi-Fi to part of the garden as much as possible) (drawing to follow)
Questions:
1. a) In the living/dining room, you see the two windows and the planned connections. Any ideas? See attached photo.
1. b) Do you have a solution for the many switches by the door to the dining room?
2. On the upper floor, you see the newly partitioned room including the access point for WLAN upstairs, possibly downstairs and mainly for the terrace/garden. Does this look good? See attached photo.
3. In all bedrooms plus the living room, double LAN outlets (CAT-7?) are planned. Is this appropriate?
4. All windows will be equipped with electric roller shutters and the switches will be placed next to the doors. Do you have good alternatives for integrating these into WLAN or similar? We haven’t yet considered the switches or whether Amazon-type switches or similar are any good.
5. The master bedroom has an additional balcony. We want to install a roller shutter switch including a pull cord to have a second emergency exit upstairs in case of fire. Does this make sense?
6. The location of the TV is suboptimal because of the two windows in the living/dining room. We don’t want to place the sofa with its back to the garden (which would be optimal for the TV) but somewhat angled from the left window, where the TV connection is also marked. Your feedback?
7. In the current plan, if the sofa is placed against the wall, we consider installing, besides two double power outlets, also the possibility to charge via USB. Practical?
8. One satellite socket each is planned only for the living room and the master bedroom. If necessary, should we place a second one including LAN in the living/dining room, in case the living room setup changes? The children will almost certainly use everything via LAN/WLAN in a few years, but for now we want to keep an option for satellite.
9. The router will be in the ground floor storage room. Will WLAN coverage also be sufficient in the living room? Would an access point from the upper floor cover the corner of the living/dining room? Any suggestions?
Please feel free to ask any questions that make it easier to understand. I hope I have explained everything clearly enough and look forward to your input.
Best regards and many thanks in advance
Westfale0101
Abbreviations:
I = LAN outlet
T = Thermostat
S = Power socket
R = Roller shutter switch
L = Light switch
Hand-drawn floor plan: two rooms with walls, doors, red power sockets (S/SS) and access point.
Room layout: living/dining room with power sockets (S) and TV connections (TV1/TV2).
Westfale0101
9 Jan 2023 11:26
Thank you very much. I will need to take another look. In our case, it is "only" an older building from the 1960s, not a new build with perfect insulation or an energy-efficient house like a KFW property.
Best regards!
