ᐅ Heating System in the Attic? Pros and Cons? Installing a New Heating System?
Created on: 8 Jan 2014 14:29
Fortuna86
Fortuna86
8 Jan 2014 14:29
Hello, we are planning to buy a house where the heating system is located in the attic. What are the advantages and disadvantages of this?
The heating system is a gas boiler from around 1998. We want to renovate the house, and this includes installing a new heating system. We aim to become as independent as possible from electricity and gas in the future. What would you recommend, and what approximate costs should we expect?
Fortuna86
8 Jan 2014 14:30
P.S. The house has an area of approximately 125 m² (1,345 ft²)
Wastl
9 Jan 2014 08:39
Fortuna86 schrieb:
We want to be as independent as possible from electricity and gas in the future.
Maybe "oil and gas"?
Being independent from electricity is a real challenge. Since the heating system is located in the attic, using wood will probably be very complicated. The pellets would all have to be pumped up to a storage area.
That leaves only solar-powered water storage (solar energy) or heat pumps (which still require electricity,...). A heat pump can also be installed in the attic. However, this will not harmonize with the existing radiators, since heat pumps usually operate at a much lower heating temperature. Gas heating tends to require higher temperatures. As a result, the heating surface area of the existing system is probably far too small (radiators or underfloor heating).
As you can see: Without a professional or specialist planner, it won’t work. Simply replacing the heating system won’t be sufficient.
