ᐅ Front door with 5-point or 3-point automatic locking system?
Created on: 4 Feb 2022 10:05
Taitv789
we need to decide on the front door for our new build.
We can choose between:
A door with a 5-point locking system (standard)
or a door with a 3-point automatic locking system (extra cost of 160€) that automatically locks itself but can always be opened from the inside.
The disadvantage of the 3-point automatic locking is that it only has 3 locking bolts instead of 5.
The advantage is that the door is always locked, so you don’t have to remember to lock it.
Has anyone had experience with the automatic locking system?
Which door would you recommend?
Taitv789
6 Feb 2022 13:09
Thank you for your responses.
I just wanted to know if there are any disadvantages to the triple automatic locking system?
If I have overlooked this, I apologize.
And with the triple automatic locking system, is it definitely possible to retrofit a different lock cylinder and a Nuki lock?
WilderSueden
6 Feb 2022 14:19
The downside is that it automatically locks. This means that a locksmith can no longer enter without causing damage if you accidentally lock yourself out.
Taitv789
6 Feb 2022 14:31
Ok, this is not so negative for me. We will store spare keys elsewhere with my parents and in-laws for emergencies.
If there is nothing else negative, we will go with them.
Tolentino11 Feb 2022 23:34
WilderSueden schrieb:
And in a way that the locksmith can no longer enter without causing damage if you accidentally lock yourself out.
By the way, that’s nonsense. They can do it; they just prefer to sell you a new lock system instead.
Nida35a11 Feb 2022 23:47
Tolentino schrieb:
That’s nonsense, by the way. They can, but they just prefer to sell you a new locking system.
Really? Until now, I also thought that automatic doors would be expensive if you’re locked out without a key.
Tolentino12 Feb 2022 00:06
It does happen, but mostly because locksmiths almost always use heavy tools, even though they could easily pick the lock with a lock pick. This is possible even with so-called security cylinders (though not all types), and definitely with standard locking cylinders. Naturally, the anti-manipulation protection has to be destroyed, but the cylinder can almost always be "picked." I witnessed this firsthand once. Burglars don’t usually do it this way because it takes longer than the well-known three to five minutes.
