ᐅ Fiber optic connection is being installed – should the existing multi-utility conduit be used?
Created on: 9 May 2022 16:39
V
Vrumfondel
Our village will be connected with fiber optic this year, and I’m wondering where the cable should best enter our house.
To explain: on the left side of the house, there is directly the street (a 40cm (16 inches) splash protection strip, edged with concreted curbs, then a 1-meter (39 inches) gravel road surface, followed by the single-lane street). At the bottom side is the paved driveway/parking space.
According to the fiber provider, the connection should be done as follows:
House connections are very often installed using a so-called no-dig method, so that no trenching is necessary. This means that an underground drilling machine or a directional boring (mole or flush pipe) is used to “shoot” or drill under the ground to the house in order to lay an empty conduit. This only requires two access pits: one at the street to connect the house connection to the main line and one directly at the house. If this trenchless method is not possible, in rare cases open trenching is used. All work is done at a depth of about 60cm (24 inches). Later, the fiber cable is blown into this empty conduit in a separate step.
No worries! The front garden or paved driveway usually will not be affected. If they are, everything will be restored to its original condition.
In the basement or ground floor, a small hole will be drilled through the outer wall so the fiber cable can enter the house interior. This hole will be properly sealed.
From initial reports in neighboring villages, it seems more likely that the construction workers arrive suddenly and never use directional boring ;-)
So here’s my consideration:
Can or may the workers use the still unused element of the multi-utility house entry point? Since that is the standard way to get utility lines into the house, that would seem obvious, right?
Alternatively, they could drill directly from the street side, above the sink on the bottom wall — as long as they manage it precisely enough not to hit any water pipes :-8
In the technical room, both positions would be fine for us. On the bottom wall there are the multi-utility box, water meter, armored box, and telephone connection installed. So there is still plenty of space for the house transfer point and network termination device—assuming the fiber provider has no further requirements regarding the distance to these installations.
What are the pros and cons of each option?
Thank you very much!
2D floor plan of a single-family house: ground floor with kitchen, living-dining area and terrace.
Tolentino10 Aug 2022 12:10
In Berlin, it’s quite intense. There is a separate company responsible for providing utility line information, but all network operators only supply their documents upon request. Depending on the provider, this service can also be chargeable. In any case, the responses to my inquiries were always limited to the public street area.
However, that was not a problem because the seller was able to tell us where the lines ran on the property.
