ᐅ Faucet for the washbasin – lever should be positioned above the basin
Created on: 14 May 2018 10:33
HäuslebauTina
HäuslebauTina
14 May 2018 10:33
Can anyone recommend a wall-mounted bathroom faucet where the on-off lever is located at the very front of the fixture?
We want a vanity at least 160 cm wide (63 inches) with two above-counter basins and wall-mounted faucets. To minimize cleaning effort, we are looking for a faucet where the on-off lever is positioned above the basins, not over the gap between the wall and the basin. Additionally, the spray pattern should be such that water does not splash out of the above-counter basins.
Here is an example of such a faucet: Dornbracht, Tara.Logic, wall-mounted single-lever basin mixer, item number: 36 804 885. Unfortunately, we have not yet been able to see it "in person" to check the spray behavior. Also, the price is not exactly a bargain ;-).
Thanks!
ruppsn
14 May 2018 13:06
If I understand correctly, you want a wall-mounted faucet that needs to be installed at a specific height. From my own experience, I can only say that this kind of setup tends to splash a lot, which is quite problematic. Since it’s in our rental apartment, it’s manageable. For our own house, however, we decided against it because of the splashing issues I mentioned. It might also be due to the combination with our Starck 3 washbasin, which has a rather angular design. As stylish as it looks, I can only advise against it for practical reasons.
Alex85
14 May 2018 17:41
I agree with that. I also strongly advise against flat, bowl-shaped sinks. They may look nice but are impractical to use.
11ant14 May 2018 18:35
HäuslebauTina schrieb:
Besides, the price is definitely not a bargain either ;-).
That wouldn’t be the point of a luxury brand anyway ;-)
HäuslebauTina
14 May 2018 22:51
Then there are deep bowl-mounted sinks... ;-)
My main concern is the faucet. I have found another option, brand Axor, Uno Select. The temperature is adjusted using a separate "knob." However, turning the water on and off works exactly as I want, directly on the faucet.
I will now try to see both faucets in person.
