ᐅ Exhaust hood with external ventilation for KfW55 standard
Created on: 28 Jun 2021 18:37
Raiweired
I want to build a single-family house according to the KfW55 standard. These houses are absolutely airtight, and the airtightness is verified with a blower door test. Is it allowed to operate a range hood in exhaust mode? For the exhaust, a duct with a diameter of 150 mm (6 inches) leading outside is required. Wouldn't this area then no longer be airtight?
Nida35a29 Jun 2021 09:15
Bookstar schrieb:
You’re going to get smoke anyway when searing steak or similar.
That’s what outdoor kitchens or gas grills are for, and from November on, just wear a hat.
Cross-ventilation hasn’t been banned yet; not everything needs to be done with recirculation/exhaust/controlled ventilation systems.
Bookstar
29 Jun 2021 10:29
Nida35a schrieb:
That’s what outdoor kitchens or gas grills are for, and from November with a hat.
Cross-ventilation hasn’t been banned yet; it’s not necessary for everything to be done with recirculated air/exhaust air/controlled ventilation systems.
Absolutely! That’s how I do it as well. But it’s reasonable for me to share my experience here and say that for the next house, I would choose exhaust ventilation again instead of recirculated air. Still, always with a downdraft extractor—I find that one really good! 🙂
halmi
29 Jun 2021 11:21
We used exhaust ventilation for years and now have a Bora Classic 2.0 with recirculation. You still get cooking and food odors inside the apartment with both systems; there’s no denying that. The Bora downdraft extractor with recirculation does a very good job for us and works better than the old Siemens exhaust hood.
borxx
29 Jun 2021 12:24
Even the above-mentioned thermal box has a significant impact on an already tight 55 cm (22 inch) wall assembly.
A U-value of 2.2 over an area of 15 x 15 cm (6 x 6 inches) is unfortunately not negligible; multiplied by 0.03 and multiplied by the heating period (Ht), it results in a similar magnitude to detailed thermal bridges for the entire house, as far as I have calculated correctly.
If it "didn't matter," I would probably install the exhaust vent regardless of whether the air is extracted through a trough, ceiling, or other means.
basti484
29 Jun 2021 22:42
We are trying our luck with a recirculating hood and an additional plasma filter. Hopefully, the ventilation system will take care of the rest. How well this will work remains to be seen.
Tarnari30 Jun 2021 03:02
There is so much out there… I had to google it first.
Sounds like something from Star Trek.
