Has anyone conducted (or had conducted) cost-effectiveness calculations for a 10 kWp system compared to a smaller one (e.g., a 5 kWp system) and compared the results? What were the findings?
Here is my calculation:
A 10 kWp system does not cost twice as much as a 5 kWp system, for example €13,300 instead of €7,600 (1340 €/kWp instead of 1530 €/kWp)*. This could be an argument that a larger system is more cost-effective.
On the other hand, with a 10 kWp system, I can only use about 20% of the generated electricity myself, while with a 5 kWp system it is about 30%.* (Self-consumption saves 23.99 cents/kWh, feeding into the grid only brings in 12.2 cents/kWh). This would be an argument that a smaller system is more cost-effective.
The question is which effect predominates.
I am comparing two 5 kWp systems with one 10 kWp system. In both cases, I assume 7000 kWh per year.
Two 5 kWp systems cost €1900 more.
Annually, they generate:
70% * 7000 kWh * 12.12 cents/kWh + 30% * 7000 kWh * 23.99 cents/kWh
€597.80 + €503.79
€1101.59
The 10 kWp system generates annually:
80% * 7000 kWh * 12.12 cents/kWh + 20% * 7000 kWh * 23.99 cents/kWh
€689.74 + €335.86
= €1025.60
So the difference in return is €76. This means the additional cost of the two 5 kWp systems is recovered in 25 years.
This leads me to the conclusion that the cost-effectiveness of both options is quite similar, and it is more a matter of personal preference how much money one wants to invest. Generally, a larger system probably pays off somewhat earlier. If a battery storage system is to be added in x years, the larger 10 kWp option also seems more reasonable to me.
Have you done similar calculations and come to similar results?
€597.80 + €503.79
€1101.59
€689.74 + €335.86
= €1025.60
Both systems are definitely overpriced at the stated purchase prices [emoji4]
Don’t get caught up in these details. Once you factor in taxes, it will drive you crazy.
(By the way, self-consumption doesn’t save you 23.99 cents. It costs 4 cents VAT for the first 5 years, and you forgo the feed-in tariff if you use the kWh yourself.)
10 kWp, if it fits and the money is available.
toxicmolotof19 Feb 2018 15:07That's right, you seem to be ignoring taxes and depreciation.
In total, I have 5.4 kWp (no more would fit), but I would say that a larger system wouldn’t have caused a significant additional financial burden.
If I had had more space, I would have chosen a bigger one.
Here is an updated calculation.
The average electricity price over the next 20 years was assumed to be 0.36 cents/kWh, corresponding to an increase of 3% per year. The return rate is considered as the key figure:
5 kWp system
Cost: 7,600 €
Annual yield:
70% * 3,500 kWh * 12.2 cents/kWh + 30% * 3,500 kWh * 36 cents/kWh
€298.90 + €378
= €676.80
Return = €676.80 / €7,600 = 8.9%
10 kWp system
Cost: 13,300 €
Annual yield:
80% * 7,000 kWh * 12.2 cents/kWh + 20% * 7,000 kWh * 36 cents/kWh
€683.20 + €504.00
= €1,187.20
Return = €1,187.20 / €13,300 = 8.9%
This leads me to the conclusion that the profitability of both options is quite similar, and it is more a matter of preference how much money one wants to invest. If you consider adding a battery storage system in x years, the larger 10 kWp option seems more reasonable.
Have you performed similar calculations and reached comparable results?
5 kWp system
Cost: 7,600 €
Annual yield:
€298.90 + €378
= €676.80
10 kWp system
Cost: 13,300 €
Annual yield:
€683.20 + €504.00
= €1,187.20
What I don’t understand is why you assume 30% self-consumption for the smaller system and 20% for the larger one.
No matter the size of the system, the proportion of self-consumption should be the same, right? Unless the system is so undersized that you inherently end up with a higher percentage.
As many have already mentioned here, the larger the system (up to 10 kWp), the faster it pays off. Especially if you can get costs down to €1100 per kWp or less. You probably won’t achieve this with a "small" 5.7 kWp system.
