ᐅ Drywall partition in the basement (new construction) – acceptable or risk of mold?
Created on: 20 Apr 2021 11:58
dpauso7766D
dpauso776620 Apr 2021 11:58Hello,
In my new build, there is a large basement room without any partitions. I would like to divide it as follows:
Front area: heating system, electrical supply, washing machine, dryer, etc.
Rear area: storage space
I have a contractor for this who wants to install a drywall partition using plasterboard.
I have read various arguments for and against drywall partitions in basements, but couldn't reach a clear conclusion because those discussions were about older buildings or basements with saunas and similar features.
In my case, it is a "dry" basement (waterproof concrete shell), and no sauna, shower, or similar installations will be added. At most, laundry might be hung on a drying rack. There is practically no ventilation (2 light wells—with plans to have one per room later) and a basement door. Insulation in the wall would not be necessary.
Is this okay, or would mold still develop?
nordanney20 Apr 2021 12:27dpauso7766 schrieb:
Is that okay, or would mold still develop then?Mold needs moisture and a cold surface where water can ideally condense.I can’t think of any reason why you shouldn’t install a drywall partition in a regular basement. It’s even common practice in damp bathrooms.
dpauso776620 Apr 2021 13:33nordanney schrieb:
Mold needs moisture and a cold wall where water can condense.
I can’t see any reason why you wouldn’t install a drywall partition in a regular basement. That’s even common in humid bathrooms.That sounds good.. I thought it might be different because a bathroom is regularly ventilated and there is an air exchange..T
taschenonkel21 Sep 2021 11:31You can run into mold problems if you cover a cold basement exterior wall, for example, with drywall. A vapor barrier must be installed here to prevent the warm, moist air from reaching the exterior wall behind the drywall.
If you build an interior wall or cover a basement interior wall with drywall, nothing like that will happen.
Seppl's Häusle22 Sep 2021 08:46I don’t see a risk of mold either.
I have the same question and am more concerned that the drywall panels might swell, causing unsightly cracks or bulges.
Does anyone have experience with this?
