ᐅ Does the IKEA UTRUSTA wire basket fit in the FYNDIG base cabinet?
Created on: 27 Apr 2016 06:59
TobWen
Hey everyone,
Does the 40mm (1.6 inches) Utrusta wire basket [1] fit into an FYNDIG base cabinet [2] or [3]?
The dimensions seem almost right, even though the middle holes for mounting are missing, but those could be drilled afterwards.
It would save me from back pain and forgotten groceries.
Tobias
TobWen
27 Apr 2016 21:29
Now I understand what you wanted to tell me. ops:
IKEA-Experte
27 Apr 2016 23:02
Oh, then I should have written better: Pull basket make slam on door.
TobWen
28 Apr 2016 00:08
The modular system you showed is interesting. I would ultimately need to install a strip at least 15 mm (0.6 inches) thick along the entire side and then attach the rails to it.
I would have to have the floors and fronts cut to size. But I am especially concerned about the double cabinet, whether the thin elements can withstand the load?!
IKEA-Experte
28 Apr 2016 13:54
What is the thickness of the side walls in FYNDIG?
TobWen
4 May 2016 11:06
Approximately 1.65 cm (0.65 inches)
IKEA-Experte
4 May 2016 11:46
Did you measure with a micrometer screw gauge? If you’re used to working with such tools, nothing can go wrong when DIYing.
16 mm (0.6 inches) is a cabinet thickness commonly used by well-known kitchen manufacturers. If you use Euro screws combined with chipboard screws, it will hold securely.
For the 40 cm (16 inches) wide cabinet, I would skip the effort and exchange it for a drawer cabinet.
