ᐅ Does it make sense to install an air conditioning system as a retrofit?
Created on: 25 Mar 2020 18:19
andimann
We have been living in the house since December 2016, and during the planning and construction phase, I never even considered installing an air conditioning system.
Basically, we manage without one. During the extreme summer of 2018, the upstairs temperature peaked at 25.5-26°C (78-79°F). That was just barely acceptable, but personally, it was borderline for sleeping. Summers like that will probably become more frequent in the future. In summer 2019, temperatures never rose above 25°C (77°F), but unfortunately there were times of very high humidity, which made it uncomfortable. Morning ventilation didn't help much then; it actually made things worse. Ventilation only works effectively if the shutters are open, but we prefer to sleep in the dark...
Since I've learned that air conditioning systems are much more affordable both in initial cost and electricity consumption than I originally thought, I now realize I should have planned for one back then. Hindsight is always 20/20...
Now I'm considering whether it would be possible to retrofit an air conditioner, at least with minimal functionality.
The requirements would be:
We have a stairwell with a half-landing and an adjacent wide hallway upstairs.
The idea is to install an indoor unit in the stairwell, above the window, directly below the upstairs ceiling. From there, the unit could blow air along the hallway and, with doors open to Child 1 / Child 2 and the bedroom, at least some cooled air would reach those rooms. Possibly supported by a oscillating fan placed in the hallway. The system would run in the morning until just after noon, when no one is home anyway. This way, the house would be pre-cooled during that time and wouldn’t keep heating up continuously. As mentioned, the goal is just to lower the temperature by about 2°C (4°F), not to cool all rooms evenly and draft-free down to 18°C (64°F).
The outdoor unit could be placed next to the ledge, and the piping routed straight up in the corner, even though that is on the north side, where our trash bins and firewood are stored. So it’s not exactly the most attractive spot...
Questions (I understand that precise predictions are difficult):
Andreas
- Cooling the air temperature upstairs by a maximum of 2-3°C (4-5°F). Keeping it under 24°C (75°F) would be perfectly fine. We don’t want it colder than that.
- Dehumidification of the air.
- Would such a setup be effective, or is it a bad idea that would just result in a cold hallway and rooms that are as warm as before? I think I've seen a similar configuration in a thread here, but I can’t find it anymore.
- What cooling capacity should I expect to need? The bedroom, hallway, and both children’s rooms together are about 65 m² (700 sq ft). I’ve seen recommendations between 4 and 6 kW (14,000 to 21,000 BTU), but since we don’t want to cool down to 19°C (66°F), just reduce the temperature slightly, should it be less?
- Are there devices or brands known for having stronger fans? We need a unit that can blow its airflow further...
- How is condensate handled in such a setup? Would we likely need to run another drain hose through the exterior wall?
Andreas
matte1987 schrieb:
I actually thought that choosing a well-known manufacturer would help me avoid these kinds of problems. Usually not, since practically everyone uses the same compressors regardless of the brand on the unit—there are only a few manufacturers for those. It’s similar to the automotive industry.
A compressor failure after 2 years is more likely due to faulty installation, oil shortage, or foreign objects in the pipes. (So also human error during installation.)
However, I would recommend getting a second opinion. Compressors are often replaced unnecessarily.
