ᐅ Direction of parquet installation: parallel or perpendicular to the incoming light in the living room
Created on: 24 May 2021 14:06
MoeTavern
Hi,
How would you lay the parquet flooring in this apartment layout? Uniformly across the light direction in the living room, or uniformly along it? The parquet will be installed uniformly, meaning there are no plans to change the orientation in different rooms. It is also decided that the hallway and kitchen areas will have parquet, just to clarify that in advance.
Maria
Grundriss eines Apartments mit Küche, Wohnzimmer, Bad, WC/Dusche, Fluren und Balkon.
11ant25 May 2021 00:57
i_b_n_a_n schrieb:
In a conversation with a carpenter friend, he recommended "30°". After implementing it once for a customer on request, he would never do it any other way.
But ideally only in a random pattern; otherwise, it’s a tedious job to create an appealing joint layout and also leads to a lot of waste.
manohara25 May 2021 06:36
Myrna_Loy schrieb:
I want to emphasize a hallway about 10 m (33 feet) long and about 1.50 m (5 feet) wide – along its length?
I don’t think this can be answered clearly at all...
When I was a student, I lived in a room that had two differently sized doors. I highlighted this difference even more by using colors. Since then, I have understood that especially emphasizing the existing features of a room can be appealing.
I would decide this based on whether I am the type of person who prefers inspiration or someone who prioritizes calmness.
K1300S25 May 2021 06:45
i_b_n_a_n schrieb:
In a conversation with a carpenter friend, he recommended "30°" to me.
But you really have to want that.
manohara25 May 2021 07:02
Personally, I always find diagonally laid flooring to be intentionally "trying too hard" and consider it unnecessary and silly, but of course, taste is subjective 🙂
K1300S25 May 2021 07:13
I can still accept a "normal" diagonal layout (even though it’s not my first choice), but two-thirds diagonal? 😱
manohara25 May 2021 07:17
A good criterion, especially from a craftsman’s perspective, is: What is easier to manufacture? Parallel (perpendicular) cuts are simpler than cutting each part diagonally...
