ᐅ Determine the electricity consumption of the air-to-water heat pump as a proportion of the total power consumption.
Created on: 2 Jan 2022 13:38
Tx-25
Hello, in 2020, we consumed about 6,800 kWh of electricity. Of this, 1,750 kWh was self-consumption from our photovoltaic system. This means our electricity purchase from the grid was 4,062 kWh. Since we have an air-to-water heat pump, the heating also runs on electricity.
How can I now separate the electricity consumption of the air-to-water heat pump from the overall costs?
We have a meter on the electrical distribution board showing 1,294.59 kWh. Additionally, there are two heat meters installed (12,082 and 2,477 MWh).
KingJulien9 Jan 2022 13:26
OWLer schrieb:
You have to take care of VAT for the photovoltaic system alone.
Maybe @Badener1970 is "on" a SHORT break 😉
OWLer9 Jan 2022 15:46
KingJulien schrieb:
Maybe @Badener1970 is "on" KUR 😉
Well, that would make sense. However, not financially if you end up losing the VAT. Anyway, we as a forum are not the point of contact for electricity meters...?
Badener1970
10 Jan 2022 21:26
guckuck2 schrieb:
No, that is all correct, it’s called a meter cascade, also known as metering concept 8.
The October 21 reference doesn’t indicate when the photovoltaic system and meters were activated … given the high values, it’s assumed this happened during the summer.
Correct, the meter was installed in June, which was also when the dry heating of the screed was running…
Badener1970
10 Jan 2022 21:27
OWLer schrieb:
Don’t change anything about point 2. If you install a cascade system, you have to take care of the VAT for the photovoltaic system anyway.
I’m afraid I don’t understand anything...???
