ᐅ Corner bricks without drainage
Created on: 7 Apr 2019 23:31
O
ollibom
O
ollibom
7 Apr 2019 23:31
My landscaper wants to install 50cm x 30m (20 inch x 98 feet) L-shaped retaining stones on the slope. Although we have heavy clay soil, he intends to place them only on gravel. We have no way to drain the accumulating water (the garden slopes down toward the planned retaining stones), so it can only infiltrate into the ground. My question: Won't these stones create a retaining wall that holds back water? The company El specifies that a drainage system should be installed inside the L-shape to prevent water from collecting behind it.
Wouldn't it be better to choose a more permeable solution?
What alternatives are there?
fragg
8 Apr 2019 08:33
There is a drainage system every 50cm (20 inches)...
O
ollibom
8 Apr 2019 13:35
No. There is no drainage on the slope. The stones are placed precisely against each other, and the joints are intended to be compacted.
Lumpi_LE
8 Apr 2019 13:42
Google image search for "drainage retaining wall" shows many pictures illustrating the correct way to do it: a drainage wall and drain pipe. However, the water still needs to be directed somewhere, for example into a soakaway, sump, or sewer.
With a garden wall, it’s not a big problem to leave this out – building the foundation on 30cm (12 inches) of gravel and backfilling with gravel also provides some drainage.
O
ollibom
8 Apr 2019 20:23
But it seems that I will end up with a damp corner on my clay floor, since water will accumulate behind the stone. Or am I wrong?
Mottenhausen
9 Apr 2019 10:29
fragg schrieb:
a drainage is installed every 50cm (20 inches)...
I agree. As long as the joints between the L-shaped blocks are not sealed watertight somehow, water will still pass through there.
