ᐅ Construction dust during home building?
Created on: 8 Jun 2020 20:30
Bauherr am L
The question is already stated above. Our electricians are currently chasing the cables. It’s incredible how much construction dust is generated. How do you handle this? Do you vacuum the shell construction from time to time?
I’m looking forward to hearing about your experiences and appreciate any tips!
AxelH.9 Jun 2020 09:55
Mycraft schrieb:
All the trades cleaned up behind themselves carefully every day.
It was exactly the same for us. Everything was exemplary.
Mycraft9 Jun 2020 10:19
I’m used to it being the same in everyday life. Every painter, drywall installer, or whoever else cleans up afterward, so why shouldn’t it be the same during house construction...
Bauherr am L
9 Jun 2020 10:39
So right now, the electricians are installing the outlet boxes. The entire shell construction is now covered with a fine stone dust. I hardly think it will be cleaned up...
haydee
9 Jun 2020 12:57
Everything was neat and clean on our site as well. It was rare for any trade to leave materials or tools behind in the evening. If they did, it was cleared away the next day.
rick20189 Jun 2020 17:07
We also had dirt on site.
I vacuumed about 150 kilograms (330 pounds) of quartz sand. It was excess from the asphalt.
The further along your build is, the cleaner the work should be.
This is only partly related to price; it mostly depends on the craftsmen’s own standards. If tradespeople don’t pay attention or clean up, you just have to talk to them. If that doesn’t work, the next level of management must get involved. That didn’t happen in our case.
Of course, if you only want the cheapest option, the site probably won’t be very clean...
wrobel9 Jun 2020 22:09
Hello
Using a vacuum cleaner during the shell construction is a bit excessive. Sweeping is completely sufficient. Before installing the screed, a bit more thorough cleaning is preferable. I consider it obvious that each trade disposes of its own waste and leaves the construction site reasonably clean and in line with the progress of the build. A vacuum cleaner only becomes truly useful just before laying the floor coverings.
Olli
