NoniBoni1321 Feb 2024 10:44Hello Dear Community,
I am planning to move my bathroom to a new room and therefore need to extend or reroute the water pipes. For this, I bought a press tool from Rems with TH profiles. I also bought suitable pipes.
However, I have encountered a problem:
My “old composite pipes” seem to have been pressed using the Rothe system, because on the one hand the pipes are marked with “Alulaser-Plus” and the press profile looks like RN20.
My question is:
Can I simply install a TH press fitting in between, or are the pipes only designed for Rothe fittings?
I would really appreciate any answers.
My question is:
nordanney21 Feb 2024 10:53NoniBoni13 schrieb:
For that, I bought a pressing tool with TH profiles from Rems. Very neat!
NoniBoni13 schrieb:
I also bought matching pipes. So you only need fittings with TH profiles – good and affordable ones like Pipetec or similar.
NoniBoni13 schrieb:
My “old composite pipes” seem to have been pressed with the Rothe system, because the pipes are marked “Alulaser-Plus” and the pressing profile looks like RN20. The fittings and pressing profile don't really matter for the pipes. The pipes just need to have the right size. RN is the profile. 20 is probably the pipe diameter. So normal 20mm (3/4 inch) multilayer pipe.
I would just cut it off (of course deburr, etc.) and continue with a Pipetec fitting with TH profile.
NoniBoni1321 Feb 2024 18:41nordanney schrieb:
Very neat!
So you only need fittings with TH profile – good and affordable ones like Pipetec or similar.
For the pipes, the fittings and the pressing profile don’t really matter. The pipes only need to have the correct size. RN is the profile. 20 will be the pipe diameter. So a standard 20mm (0.8 inch) MSVR pipe.
I would just cut it off (of course deburr etc.) and continue with a Pipetec fitting TH.Thank you very much for your feedback. I’m relieved now. I will do it that way. I wish you a great day.
