ᐅ Can the air-to-water heat pump also be used for cooling in the summer?
Created on: 30 May 2016 00:40
dieter_m
...according to some reports, this can work (depending on the construction type).
I imagine it like this: In winter, water circulates through the underfloor heating loops at a temperature a few degrees warmer than my desired room temperature, and in summer, when it’s around 35°C (95°F) outside, the heat pump delivers water at 18°C (64°F) or even cooler. Since the sun is shining, the heat pump runs on its own electricity, and I have a comfortable 23°C (73°F) inside the house.
Of course, the cold air doesn’t rise, so you might only have cold feet, and if it’s set too cool, maybe some damp spots.
Maybe this isn’t needed at all if the building is well insulated and the indoor temperature stays about 10 degrees lower than outside.
Still, I would be interested in your opinions on this topic.
Regards, dieter_m
Sebastian79
30 May 2016 10:18
Only a proper split air conditioning system is effective for this.
I have prepared it for four rooms, but due to our financial situation, it will probably be installed later. Preparation costs are around 300 euros.
Steffen80
30 May 2016 11:15
Sebastian79 schrieb:
Only a proper split air conditioner makes sense there.
I have prepared it in four rooms, but due to our financial situation, it will probably come later. Preparation costs maybe 300 euros...
Exactly! As I said... for us, 7500 EUR including installation. The living room is 65 m² (700 sq ft) in size. It definitely requires some capacity.
Sebastian79
30 May 2016 11:43
That doesn’t really increase the price much – the differences between the lowest and highest output are usually around 200-300 euros per unit.
For four Mitsubishi design units including the multisplit system, I pay about 4000 euros.
tabtab30 May 2016 13:36
Why do you have air conditioning? With well-insulated houses, that shouldn’t be an issue anymore, right?
Uwe8230 May 2016 13:48
Well-insulated houses can resist heat for a while, as the walls store the warmth and then release it gradually. However, if a heatwave lasts for an extended period, even the best-insulated building will eventually warm up, despite natural or mechanical ventilation. At that point, maintaining a comfortable 20°C (68°F) indoors becomes difficult. It also takes a long time to get rid of the accumulated heat.
Therefore, air conditioning may make the situation more bearable. We do not plan to have one initially, but it might be considered and installed if necessary in the future.
Sebastian79
30 May 2016 13:48
That’s actually the main issue 😉 – no matter how well insulated and protected against summer heat, eventually it just gets warm inside the house.
And then you “need” air conditioning – humidity is also a factor.
For a new build, I would always pre-install the infrastructure for air conditioning in certain rooms, meaning run the necessary wiring. Retrofitting later on is quite easy.
