ᐅ Calculate the annual performance factor (seasonal performance factor) based on electricity consumption?
Created on: 3 Nov 2020 13:09
M4rvinHi,
I have been operating an air-to-water heat pump in my new build for a year now. Is there a way to calculate whether it is running efficiently?
Elco Aerotop Split 07M-R
Heating capacity 6.4 kW
Seasonal performance factor heating 4.77
Seasonal performance factor domestic hot water 3.58
Overall seasonal performance factor 4.5
Annual consumption heating/hot water = 2630 kWh
The main issue will probably be separating heating from hot water usage, right?
I also cannot find any option in the heating controller to display energy amounts.
Thanks in advance!
M4rvin
Thanks in advance!
M4rvin
Neueshaus20203 Nov 2020 16:23Are these values from the heat pump itself? If the overall seasonal performance factor (SPF) is a rough average of heating and domestic hot water, then you can calculate the individual shares.
Difference between heating SPF and hot water SPF = 1.19
Difference between heating SPF and overall SPF = 0.27
Difference between hot water SPF and overall SPF = 0.92
Share of hot water = 0.92 / 1.19 * 100 = 77.3
Share of heating = 0.27 / 1.19 * 100 = 22.7
So maybe 22.7% domestic hot water and 77.3% heating. That would be...
0.227 * 2630 kWh = 597 kWh for hot water and
0.773 * 2630 kWh = 2033 kWh for heating.
Does this help?
Does this help?
