ᐅ Calculate the annual performance factor (seasonal performance factor) based on electricity consumption?
Created on: 3 Nov 2020 13:09
M4rvin
Hi,
I have been operating an air-to-water heat pump in my new build for a year now. Is there a way to calculate whether it is running efficiently?
Elco Aerotop Split 07M-R
Heating capacity 6.4 kW
Seasonal performance factor heating 4.77
Seasonal performance factor domestic hot water 3.58
Overall seasonal performance factor 4.5
Annual consumption heating/hot water = 2630 kWh
The main issue will probably be separating heating from hot water usage, right?
I also cannot find any option in the heating controller to display energy amounts.
Thanks in advance!
M4rvin
T_im_Norden
4 Nov 2020 06:43
Has the heat pump been subsidized by the BAFA?
Then you should also have a heat meter; otherwise, there is often a menu option for generated heat or something similar.
This is rather imprecise but better than nothing.
Otherwise, you have no way to check which annual performance factor you have achieved.
Lumpi_LE
4 Nov 2020 07:17
Without a heat meter, you cannot determine the annual performance factor.
About 2000 kWh for heating sounds reasonable, but this could correspond to an annual performance factor of 3 to 6...
tomtom794 Nov 2020 18:04
When calculating the annual performance factor, you take the total kWh and the total heat output, right? For example, in our case, the hot water consumption is almost 50% of the total heat output.
