ᐅ Building an End-Terrace House – What Technical Requirements Should Be Considered?
Created on: 4 Dec 2018 09:30
goalkeeperG
goalkeeper4 Dec 2018 09:30Hello everyone,
First of all, I would like to say a friendly hello to the group. I just registered because I couldn’t find any help on Google for my question.
We are planning to apply for a corner townhouse plot in our community. However, the municipality has not hired a developer to build the houses; instead, the houses have to be constructed independently by the owners.
There is a points system for the application, where factors like the number of children, how long you have lived in the community, and so on are weighted differently.
If you join forces with other interested parties and apply together, these points are added up, increasing your chances of being allocated a building plot. At the same time, you commit to building together, meaning you also have to coordinate with a developer.
We have tried to find people from our community, where we also live, who share the same ideas for building. This turned out to be impossible, as everyone has different opinions on how to build.
Therefore, we will probably apply alone for an end townhouse. However, I am now wondering if there are any laws or regulations regarding self-managed construction of townhouses? For example, if we build two full floors with an attic and a mono-pitched roof, is it allowed for the middle house to have a gable roof and only two full floors? Or does the first person to build set the standard that the others must follow?
Please forgive me if these are beginner questions — but I am one.
Thank you for your help!
Mottenhausen4 Dec 2018 09:42There should definitely be a development plan.
For a row of terraced houses built closely together, it should be quite strict and specify, for example, building lines, dimensions, number of storeys, eaves height, ridge height, etc., so that a proper terraced house is created.
I haven’t read through the development plan (if you want to have an active discussion here, I would suggest outlining the key points instead of expecting everyone to read the entire plan. Neither I nor many others have the time for that), but can you specifically apply for a semi-detached house?
From what I know, you can express preferences, but when the allocation is made, you might have to be content with a mid-terrace house. That’s the first point. Would that be acceptable for you?
Otherwise, at least for semi-detached houses, I’m aware that one half can be built significantly earlier than the other. I’m not sure how it works with terraced houses, as it could be that the two semi-detached houses are already built and the middle house would have to be squeezed in between. No idea if that poses a structural challenge.
goalkeeper4 Dec 2018 10:19Exactly. The construction method is open.
