Bauexperte16 Mar 2012 22:47Hello,
The facade is rarely gray or black.
Yes.
spale schrieb:
can someone explain to me the difference between base paint and facade paint?
spale schrieb:
Can I also use base paint to paint the facade or vice versa?
Yes.
Bauexperte17 Mar 2012 13:47Hello,
Color is just color at first – regardless of its different types and purposes.
What you are probably referring to is a base coat plaster, which should be designed to prevent moisture from penetrating the masonry; that is usually why a bituminous thick coat is applied before a "base paint" is put on. Most homeowners choose to paint this in a gray color because dirt splashes from the ground are less noticeable when it rains.
However, you can use this paint to cover your entire house.
Kind regards
spale schrieb:
So what exactly does this mean? Is there no difference other than the color?
Kind regards
No, I don’t mean base plaster. My house is finished because I bought it one year ago. However, there are some spots on the base and on the facade that I should repair. That’s why I’m asking: what is the difference between base paint and facade paint? Both base paint and facade paint are sold—so what is the difference? As far as I know, both types of paint are water-repellent, or...? There must be a reason for base paint and facade paint to exist. Best regards to everyone.
