A few years ago, we bought an older house in Croatia. Since then, we have almost completely renovated the interior. Now, at the latest by next spring, we plan to install external wall insulation and apply a new facade paint.
My question is: Which facade paint would you recommend? I’m not very imaginative when it comes to colors. We definitely don’t want plain white, as we find it quite boring. Personally, I like anthracite on houses.
The tree by the facade will be cut down soon.
On the first floor, the old wooden window will be replaced by a window four times larger, in white. New white uPVC windows have already been installed.
The roof was redone two years ago.
As a little inspiration, here is a picture of the house attached.
Many thanks in advance for your replies.
nordanney15 May 2025 10:52Croatia = regularly pleasantly warm with sunshine?
There is a good reason why light colors and white are commonly used in southern regions.
I would choose colors between white and terracotta. Definitely avoid dark colors.
Hello nordanney, thank you for the quick response. However, the house is not located by the sea, but rather inland, near Zagreb. The temperatures are probably somewhat higher than in Germany.
Would you still advise against using dark colors?
What do you think of the color "Cappuccino"?
nordanney15 May 2025 14:03c1member schrieb:
What do you think about the color "Cappuccino"?I can imagine that as well. It’s close to terracotta – so basically in the range of earthy tones.It also has to suit the regional style.
In my opinion, anthracite definitely doesn’t suit that, and even less with the red roof. Setting aside the heat absorption issue. A bright white color probably wouldn’t fit the region either. I could well imagine a very light terracotta / ocher / beige. It should be light and still provide a clear contrast to the roof color.
Andreas
Andreas
