ᐅ Is a balcony drain channel necessary at the balcony door? No roof covering!
Created on: 19 May 2016 16:19
fraubauerF
fraubauer19 May 2016 16:19Good day.
This point is not entirely clear to me either. I have already done a lot of research on Google.
Our balcony faces east and south. It is not covered.
It is constructed on steel beams with a light granite slab on a gravel bed system.
Now, I have read that there should be some kind of “drip edge” in front of the balcony door to prevent water from flowing inside during a “once-in-a-century” rain event.
However, I do not see this feature.
Am I allowed to raise a complaint about this?
Thank you!
Thank you!
Bieber081519 May 2016 23:50fraubauer schrieb:
I have read that there must be a kind of "drip edge" in front of the balcony door to prevent water from flowing in during a "once-in-a-century rain event." Regarding flat roof guidelines and DIN 18195: without a drainage channel and without a canopy, the threshold must be at least 15 cm (6 inches) high. If the threshold is lower, special measures are required, such as a drainage channel, which then allows the threshold to be lowered to 5 cm (2 inches).
For barrier-free access, the threshold should be less than 2 cm (0.8 inches), which calls for especially careful planning.
If linking were permitted here, I would share sources, but with the keywords given, you should be able to find relevant information.
fraubauer20 May 2016 09:02BauRoman schrieb:
Could you tell us the height difference between the top edge of the balcony floor covering and the top edge of the door threshold when the balcony door is open? (This is the highest point of the door frame. When entering or exiting, people usually catch their foot on it. 🙂 )Hello.
So, the difference is about 6 cm (2.4 inches)!
Is that acceptable, or should there be a drainage channel in front of the balcony door?
Thank you
