ᐅ Attach Ikea Expedit Desk to 2x2 Shelf Unit
Created on: 6 Oct 2010 13:00
Flauschi
Flauschi
6 Oct 2010 13:00
I wanted to attach the Expedit desk to the 2x2 Expedit unit (the smallest one) available for 19 euros.
Now I realize that the metal mounting bracket on the desk is only designed for the narrow shelves in the Expedit unit. I would need the mounting brackets configured so that there is a wide support on both sides.
Has anyone encountered a similar problem?
Drilling into the Expedit unit might compromise its structural integrity because it would damage the honeycomb structure, right?
Thanks in advance and best regards,
Florian
Maverick1854
8 Oct 2010 22:28
That’s correct. You cannot drill into an Expedit because the inside of the Expedit is hollow. You can only try to enlarge the surface area, for example by using a panel, to increase the mounting area. If I understood that correctly.
stormwitch
30 Oct 2010 17:38
Hello!
Did you find a solution? I have the same problem 😉
