DaniMartinez schrieb:
Do you happen to know how much more expensive the Gealan Kubus frame is compared to the S9000? No. I haven’t been a window dealer for two years as of this month 🙂
Not really! 2.70m (8.9 ft) isn’t wide enough. A 1.20m (3.9 ft) passage for a lift-and-slide door can’t be serious, right?
nordanney22 Jul 2021 15:2211ant schrieb:
Gealan is my recommendation for non-white PVC windows because I generally consider surface coloring through co-extrusion to be a higher-quality alternative compared to foiling. That’s true. However, it’s not cheap – but definitely worth the price.
nordanney schrieb:
That's right. It's not cheap either – but definitely worth the price.Yes, the more complex process naturally costs more – and, to be honest, I wouldn't give it away for free either. And since I believe that the "profile 'behind the color'" is only equivalent to those of other quality manufacturers, I recommend it primarily for customers who are not yet well-informed ;-)https://www.instagram.com/11antgmxde/
DaniMartinez23 Jul 2021 10:2811ant schrieb:
No. This month marks two years since I stopped being a window dealer 🙂
A 1.20 meter (4 feet) passage width for a lift-and-slide door is no joke, right? We wanted to minimize the space lost inside due to a French or standard patio door!
That’s why we considered a lift-and-slide door… of course, it’s an expensive solution, but from a space perspective, it’s the best option, isn’t it?
You once mentioned in another post that lift-and-slide doors should be at least 2.50 meters (8 feet) wide!
You once mentioned in another post that lift-and-slide doors should be at least 2.50m (8 feet 2 inches) wide! Oh, I probably should have said "at least that much" ;-)
I'll link here the post with your current floor plans (and you can provide the elevations afterwards).
