ᐅ Aerated Concrete vs. Sand-Lime Brick Interior Walls
Created on: 3 Mar 2016 08:55
nils1985
nils1985
3 Mar 2016 08:55
Good morning dear forum,
I would like to hear your opinions on the construction of interior walls in a new build. The options are as follows: 17.5 cm (7 inches) aerated concrete or 17.5 cm (7 inches) and 11.5 cm (4.5 inches) sand-lime brick.
What are the advantages and disadvantages of each wall construction?
How do they perform in terms of moisture regulation, sound insulation, and thermal insulation?
Nils
Sebastian79
3 Mar 2016 09:03
Sound insulation is the only thing that matters for interior walls in your list.
And it is better with calcium silicate blocks, but don’t expect miracles – not with 11.5cm (5 inches) walls (which are still better in calcium silicate than aerated concrete), plus the doors tend to be the weak spots.
What kind of walls do you have on the outside?
nils1985
3 Mar 2016 09:21
The exterior walls are, I believe, 24.5 or 27.5 cm (10 or 11 inches) aerated concrete, insulation (thickness unknown), and then 11.5 cm (4.5 inches) facing brick.
