F
FrankChief10 Apr 2024 10:16Hello,
we have a newly built house and are experiencing waterlogging issues in the garden.
There is about 50 cm (20 inches) of topsoil, which already contains some clay, followed by approximately 1.5 m (5 feet) of a thick clay layer.
The clay layer only allows water to pass through very slowly, so the garden remains waterlogged for about 1-2 days. Excess water can drain away through a French drain (soakaway) as long as there is a slope, but the soil also settles unevenly.
However, waterlogging still occurs in the soil itself, especially within the top 40 cm (16 inches), which plants do not tolerate well.
We cannot loosen the clay layer even with a rotary tiller. How can we improve the soil? Would it be sufficient to spread, for example, 10 tons of river sand over approximately 180 m² (1,940 sq ft) and incorporate a soil activator by tilling it in?
What else can we do?
Would it help to plant deep-rooted plants for one year, till the soil again next year, and then finally plant the lawn?
NatureSys10 Apr 2024 10:28If I understand your post correctly, the house is already completely finished and now it’s only about the garden area of the property?
Or is it about the entire property?
F
FrankChief10 Apr 2024 10:28The house is fully finished; only the garden remains, which is causing us problems with waterlogging.
nordanney10 Apr 2024 10:46FrankChief schrieb:
What can we do?Since you can’t really improve the topsoil—the upper 50cm (20 inches)—after heavy rain it doesn’t matter whether it consists of gravel, topsoil, sand, or something else if there is a solid barrier layer underneath.Option: Buy or borrow a soil auger (even a hand auger can reach that deep) and drill drainage holes through the clay layer (assuming there is actually permeable soil beneath). Neighbors have tried this and had great success.
Otherwise: Is drainage possible?
F
FrankChief10 Apr 2024 10:49We have already made a few holes, but then we would have to make many holes, and disposing of the clay is not that easy.
Drainage pipes could be installed and connected to the soakaway to help with water infiltration.
How does drainage behave in summer? Will the lawn turn brown and the flowers dry out in areas where the drainage is installed?
Sand still needs to be added anyway to loosen the topsoil.
nordanney10 Apr 2024 10:52FrankChief schrieb:
How does drainage behave in summer? Does the lawn turn brown and the flowers dry out where the drainage is installed? Of course, nothing happens (due to the drainage). The drainage simply removes excess water. If you had "normal" soil, the excess water would also be drained—just into deeper layers.
Normal lawn roots only grow about 15-30cm (6-12 inches) deep. When it gets hot in summer, the lawn will turn brown anyway (unless you water it properly).
