ᐅ Conduits for fiber optic cables have been filled in or covered up.
Created on: 6 Mar 2024 09:13
Bibi Bavaria
Bibi Bavaria
6 Mar 2024 09:13
What can be done? Does anyone have experience with this? A building with 5 condominiums built in 2018. Fiber optic cable was only installed in the street after the house was completed and now it cannot be routed into the building because the conduit pipes were supposedly sealed due to fire safety concerns.
X
xMisterDx
7 Mar 2024 08:26
What else can you do except contact the responsible authorities? Fiber optic providers, property owners, the civil engineering department...
And as everywhere else, the saying holds true:
Persistent dripping wears away the stone. You don’t have to bother people every day, but every now and then send an email or, even better, make a call to remind them and show that “You won’t get rid of me, forget it.”
Because you can count on that. Getting quick results is unlikely. These things take time.
U
user-d29
7 Mar 2024 08:29
Bibi Bavaria schrieb:
What can be done? Does anyone have experience with this? A building with 5 condominiums, built in 2018. Fiber optic cable was only installed in the street after the house was completed, but it cannot be brought into the building now because the empty conduits were supposedly sealed off due to fire safety concerns.
Then they should just fish the cable through again. That’s a common procedure.
X
xMisterDx
7 Mar 2024 20:33
nordanney schrieb:
Then they will just have to reroute the cable. That’s a common procedure.
Try passing a cable through a firestop. Not even a G36 can get through that.
U
user-d29
7 Mar 2024 22:02
xMisterDx schrieb:
Shoot through a fire barrier. Not even a G36 will get through that.
Which fire barrier are you referring to in the multifamily house of the OP? Are the basement exterior walls each built as fire barriers?
sysrun80
10 Mar 2024 22:01
Wait a moment: You are certainly referring to the pipes running from the basement into the residential units, right? Yes, that is relevant for fire protection.
