ᐅ Conduits for fiber optic cables have been filled in or covered up.
Created on: 6 Mar 2024 09:13
Bibi BavariaB
Bibi Bavaria6 Mar 2024 09:13What can be done? Does anyone have experience with this? A building with 5 condominiums built in 2018. Fiber optic cable was only installed in the street after the house was completed and now it cannot be routed into the building because the conduit pipes were supposedly sealed due to fire safety concerns.
X
xMisterDx7 Mar 2024 08:26What else can you do except contact the responsible authorities? Fiber optic providers, property owners, the civil engineering department...
And as everywhere else, the saying holds true:
Persistent dripping wears away the stone. You don’t have to bother people every day, but every now and then send an email or, even better, make a call to remind them and show that “You won’t get rid of me, forget it.”
Because you can count on that. Getting quick results is unlikely. These things take time.
nordanney7 Mar 2024 08:29Bibi Bavaria schrieb:
What can be done? Does anyone have experience with this? A building with 5 condominiums, built in 2018. Fiber optic cable was only installed in the street after the house was completed, but it cannot be brought into the building now because the empty conduits were supposedly sealed off due to fire safety concerns. Then they should just fish the cable through again. That’s a common procedure.
X
xMisterDx7 Mar 2024 20:33nordanney schrieb:
Then they will just have to reroute the cable. That’s a common procedure.Try passing a cable through a firestop. Not even a G36 can get through that.
nordanney7 Mar 2024 22:02xMisterDx schrieb:
Shoot through a fire barrier. Not even a G36 will get through that.Which fire barrier are you referring to in the multifamily house of the OP? Are the basement exterior walls each built as fire barriers?
